Door window question
Old Oct 10, 2009 | 01:45 PM
jefxxo's Avatar
jefxxo
Im replacing my driver door. It has power windows, but the window itself sits in a bar. Which has the arm that slides into it. Now, where the window sits in this bar there is some kind of felt or rubber that holds it into this bar. But im in need of something to do this. Any idea what this stuff is?
Old Oct 10, 2009 | 03:23 PM
Volvo92906's Avatar
Volvo92906
window channel molding?
Old Oct 10, 2009 | 05:30 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
They are crimped in to the channel from the factory.
Most replacements come with the channel already attached. (at least ALL the ones available to me 2 weeks ago when I did it)
Silicone may work for you, but I would use a urethane or epoxy to bond it in if I had to.
Old Oct 10, 2009 | 06:27 PM
Diesel_Brad's Avatar
Diesel_Brad
It is a rubber/urathane gasket. You can use a expoxy for glass or urathane or this from LMC LMC Truck Parts - Page 16
part # 49-9300 location 8
Old Oct 10, 2009 | 06:29 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Go to any autoglass shop and buy some "glass tape."
This is the stuff used to hold the glass into the channel.
