351 is knocking
Old Oct 9, 2009 | 03:05 PM
crestofir15's Avatar
crestofir15
351 is knocking
hey i got a 92 150 with a EOD4 trans and a 351 the other day and it knocks real bad. still runs good and everything but it knocks to loud for me to drive so i took it apart im about to go take off the valve covers to check that out. but i was wanting to know how check or adjust the valves or what evers under the valve covers also i should be able to put a 87 302 with a manual 4 speed in the same truck right?
Old Oct 9, 2009 | 08:08 PM
wolfsmurf's Avatar
wolfsmurf
there us nothing to adjust on a ford small block under the valve covers. rockers are a bolt on and forget them thing under there. if there is a knock in the engine it is either a rod or a main. as for the 302 it till bolt right up but you will have to check the firing order as 351's have a different firing order than most 302's( some H O model 302's had 351 firing order). i think the ecm would have to be changed or maybe its just the wiring harness unless you going carb on the 302 .the 4 speed is do-able but there will be lots of stuff you will need of the manual tranny truck as in pedals and such.
