Dashpad help????? Not a nut location question!!
Old Oct 8, 2009 | 12:40 PM
FEcustom79's Avatar
FEcustom79
Im in the middle of pulling my dash pad out when i get to the last two nuts, the one in the middle front and the drivers side front corner, and wouldn't u know it they turn but do not come off, anyone ever have this problem??? I'm gonna pull the front dash section off to paint anyways but wanted to know of any solutions other than holding the bolt with a pair of pliers and hopfully not marring up the threads. Any suggestions would be taken onto consideration.
Old Oct 8, 2009 | 01:09 PM
scottlane's Avatar
scottlane
I think you're on the right path.
I would only suggest adding duct tape to the jaws of the pliers. It will hold and give in a little to the threads.
Old Oct 8, 2009 | 01:25 PM
FEcustom79's Avatar
FEcustom79
Sorry guess I wasnt clear enough, I meant how to fix the bolt spin?
Old Oct 8, 2009 | 04:48 PM
FEcustom79's Avatar
FEcustom79
Nobody has ever had this problem before??
Old Oct 8, 2009 | 05:09 PM
Furyus1's Avatar
Furyus1
I've never tried taking my dash pad out but, I'm wondering if something like JB Weld or some kind of epoxy could be used to glue the studs in place...
Old Oct 8, 2009 | 05:16 PM
offroadbronco's Avatar
offroadbronco
It is the nut just spinning (meaning the threads are fubar'd) or is the stud spinning as well?
Old Oct 8, 2009 | 05:18 PM
first today's Avatar
first today
Tape up a flat head and put it between the pad and dash. Apply pressure by prying the pad away from the dash. While doing that try to undo the nut with your wrench. It is delicate work but I have been successful that way in the past.
Old Oct 9, 2009 | 04:06 AM
FEcustom79's Avatar
FEcustom79
The stud spins in the pad, im going to pull the front dash section off tommorrow to resolve the issue.
Old Oct 9, 2009 | 11:10 AM
BigBlue&Goldie's Avatar
BigBlue&Goldie
I had the same problem pulling my glove box trim piece out.....I ended up just prying the things off.
Old Oct 9, 2009 | 11:20 AM
cfrazier77's Avatar
cfrazier77
You can cut the heads off too. The pad will lift off then and you can then figure out how to keep the part in the pad from spinning. You are going to have to do that anyway in order to reinstall it. You would have to get 2 replacement bolts though.
Old Oct 9, 2009 | 04:17 PM
FEcustom79's Avatar
FEcustom79
I'm pulling the front section of the dash of to paint the metal anyways so ill just put the pad back on while out of the truck, so ill make the hold the threads thing work instead of risking permenant damage to the pad beings they are so damn expensive. (Thats why im going with painting the interior in the first place, on top of having a creme center console and slate gray seat trim w/blue dash and door panels so everything is going to be flat black. Hoping the high adhesion promoter in the paint will bind with the carpet. My auto body guy suggested the paint to me and said it doesnt make the carpet stiff.) Thanks to all for the advise, I really appreciate the input and out of the box ideas and suggestions everybody had to offer.
Old Oct 9, 2009 | 04:24 PM
FEcustom79's Avatar
FEcustom79
Thanks again for all the ideas, everybody that responded with an idea got a rep point from me.
GMT
Jul 2, 2013 04:54 AM
Infinite Monkeys
May 20, 2013 08:03 PM
bomberchamp
Aug 21, 2010 08:49 PM
seawulff
Aug 14, 2006 06:08 PM
