I'm hoping with a Truetrac, traction bars to prevent axle wrap, and a set of ET Streets or something, I'll be able to do boosted launches in my race tune.
Do you have any ET Streets or drag slicks in mind that you'd go with? Also would there be any benefits of going to a Truetrac and just running a limited slip? Would traction bars like the Caltrac present some problems when towing?
Trying to figure out the best combo of work/play for a 2wd I've got.
I use Micky Thompson ET Streets on my Lightning for when I drag race it, I just don't know if MT ET Streets are available in the correct size for my F250. I haven't looked into it yet.
When the OEM limited slip diff went out on my L, I decided on the Detroit Truetrac because unlike the OEM version, it's a clutchless limited slip diff, so it doesn't wear out like the OEM diff.
The Truetrac has great street manners, has worked well under all the conditions I've put my L through, from autocrossing to towing, to hauling (the L was my previous work truck) to drag racing so I know it will do great in my F250.
As for the Caltracs, I dunno how well slapper type bars work with heavy towing. As much as I like Caltracs, I prefer the Rancho type traction bars to eliminate axle wrap.
I actually have Competition Engineering Slide-A-Links on my L and LOVE them, but CE doesn't make Slide-A-Links for the F250 trucks.
