Help!
Old Oct 6, 2009 | 03:20 AM
The_Wretched's Avatar
The_Wretched
Help!
Im new to this forum and need help. I am the proud second owner of this ALL ORIGINAL 1959 F600 Corpus Christi Street Scene Forums ...... I need to know where to find parts for this dinosaur! i have a cracked brake line and cant find it anywhere. i have searched and searched and havent found anything at all. Any help is greatly appreciated.
also where can i find a vin de-coder for this generation? thanks
Old Oct 6, 2009 | 04:22 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Welcome to FTE
Is this an all steel brake line?
If so, you'll have to make it up from bulk tubing, nuts and ferrules, using a tubing bender.
Ford did not sell any steel brakes lines, they only came on new vehicles.
AFAIK, no aftermarket parts supplier reproduces these steel brake lines, because there's a gazillion different variations.
If this is a one piece steel and rubber brake hose, which one do you need?
You can post the VIN, and all the codes found on the Rating Plate here on FTE, I can decode all of it.
Or send it to me in a P/M or by email...click on my user name for contact info.
Old Oct 6, 2009 | 02:31 PM
The_Wretched
wow thanks! ima go get the vin now
