Sponsored by: Auxito
blower motor replace
Old Oct 5, 2009 | 09:52 PM
snazynismo's Avatar
snazynismo
Is there a way to take the blower motor for the heater out with out taking the WHOLE dash out or is this another dealer money maker
Old Oct 6, 2009 | 07:13 AM
redwood's Avatar
redwood
I don't know what vehicle you have. If it's similar to mine, then AllData says the following:
REMOVAL
All Vehicles
1. Remove the RH lower instrument panel insulator.
2. If equipped, remove the dealer installed air filter and brackets.
3. Remove the passenger side scuff plate.
4. Remove the passenger side kick panel.
Position aside the weatherstrip.
5. Disconnect and detach the electrical connector.
6. Position back the carpet.
EATC Vehicles
7. Disconnect the aspirator tube and remove the screw.
8. Remove the aspirator tube extension.
Remove the screws.
All Vehicles
9. Disconnect the electrical connector.
10. Remove the screws and remove the blower motor.
11. Remove the wheel from the blower motor.
Remove the dip.
Remove the blower wheel.
INSTALLATION
1. To install, reverse the removal procedure.
hotrod351
Jul 29, 2016 12:50 PM
dhuddleson
Mar 10, 2016 04:19 PM
interstategar
Feb 11, 2016 11:52 AM
gtmustang00
Feb 20, 2012 03:41 AM
railbag
1997 - 2003 F150
Nov 7, 2010 07:52 PM
