Cold Morning= A ton of white smoke, Misfires and no power for about 4 miles.
Ok its a 99 and I know my Glow Plug Relay is shot and need to get one, cause I have forever been using starting fluid to fire it up when its cold outside. Anyhow, my main problem is that when it first starts up it runs like dog! It has no power and takes about 3 miles to warm up and then clean up. All of sudden it will just gain power and be perfectly fine out of no where. What gives?
You can be doing a lot of harm to your motor by using a starting fluid. Our glow plugs get white hot when energized to effectively start our trucks. When you use the starting fluid, it hits that white hot glow plug and can cause the tip of the glow plug to explode and mushroom the end. When that happens the bad glow plug can not be replaced with out removing the head.
Do you do the screw driver trick with the key on the "on" position
PS the Starting fluid is a myth, you can only have a big issue if you do it wrong. You should always wait for the wait to start light to turn off then spray, then crank over to get it in, then cycle the key. I and many others I know have done this forever and none of us have ever had a issue.
Be careful with the myths. The WTS light has absolutely nothing to do with how long the glow plugs are activated. Ask any of the thousands of folks who have installed the GPR LED, or check this yourself with a volt meter after you replace your GPR with a working one. The glow plugs will stay on up to 120 seconds. The light won't stay on anywhere near that long.
The key position has nothing to do with the screwdriver trick. When you do this you're taking battery voltage and applying it directly to the wires leading to the glow plugs. The key can be off and in your pocket and the GP's will still get the juice (and the screwdriver might get a little hot).
It take three to four miles of driving before the motor starts to run well seems excessive to me. What kind of air temps are we talking about? When is the last time oil and fuel filters were changed? What kind of oil is being used? Is the oil level were it should be?
Are the batteries and starting system in good shape?
Nick
Nick
it sounds like to me that your EBPV is closed for engine warm up, once it opens, then your truck runs fine. this happens alot with these trucks. Ever sice i deleted my EBPV, i no longer have the problem. it is perfectly normal. Cold cylinders will not cause the truck to run like he is describing with no power.
re
