Performance 351w wont start- Help Conanski!!
Old Oct 5, 2009 | 06:20 PM
BRay09's Avatar
BRay09
I have a 74 351w that was bored .040 over and rebuilt. Going in and on the motor is Crane 444232 cam, GT40 heads with 1.7 RR and Flowtech LTs, stock plenum and intake. Motor is now in the truck and wont start. I did a compression test on the #1 cylindar and got 55 psi. Ouch. somethings wrong here, but what? Are the valve lashes in the heads wrong?
See thread for more info: https://www.ford-trucks.com/forums/8...ont-start.html.
BRay09's Avatar
BRay09
Heres another thing that struck my mind. When installing the cam and removing the timing gear and chain, was there a certain way the gears were supposed to go back on? It all came off easily and the gears didnt come out of the chain, so im sure they went on the same they came off. could this be my problem? <!-- / message -->
<!-- controls -->
Old Oct 5, 2009 | 07:33 PM
Conanski's Avatar
Conanski
Well yeah, with #1 piston on TDC on the compression stroke(both valves closed) the timing chain will be installed with the timing mark on both gears facing each other.
Old Oct 5, 2009 | 07:35 PM
jplinville's Avatar
jplinville
Check to make sure your timing marks are aligned. From the sound of the last thread, it's off.
Old Oct 5, 2009 | 07:45 PM
BRay09's Avatar
BRay09
Thats most likely my problem then. I guess you live and learn. We'll see about doing this all over tomorrow. duh, BRay, DUH
Old Oct 6, 2009 | 11:23 AM
BRay09's Avatar
BRay09
this can all be done in the truck, correct? i dont have to pull the motor again? and can the oil stay in the pan, or does that have to be drained too?
All i should need is the timing cover gasket and a new front seal, i think? lol
Old Oct 6, 2009 | 11:30 AM
BRay09's Avatar
BRay09
Also, what would be the best plug and wires for this application? I put in 8mm autolite wires and autolite copper plugs (pt num: 764) from advanced auto
Old Oct 6, 2009 | 11:32 AM
lew52's Avatar
lew52
The motor can stay in , just waterpump & timing cover . Drain the coolant . If you get anythink in the oil you will need to change it .... Lew
Old Oct 6, 2009 | 11:42 AM
BRay09's Avatar
BRay09
when i first start it up, shoulod i rev it to 1500-2000 rpm for 15 mins, or should i just let it idle and let everything set for like 30 minss or so? And after this peroid, should i change the oil, or drive my 500 or so miles with this oil and break in additive?
Old Oct 6, 2009 | 11:43 AM
Lazy K's Avatar
Lazy K
When you have no1 at TDC on the compression stroke and have the cam set as per the marks don`t forget to reset the dist rotor to point to No1 plug wire.
Old Oct 6, 2009 | 11:48 AM
BRay09's Avatar
BRay09
Is there a way to tell the compression stroke of the no 1 pistion without taking off the valve cover? Gotta remove the top end of the motor to get to it. Kinda like to stay away from that if i can.
Old Oct 6, 2009 | 12:00 PM
Lazy K's Avatar
Lazy K
Do what a previous poster suggested and either turn the crank over quickly by hand or on the starter while holding a finger on the No1 plug hole. When you feel a rush of air out of the plug hole you will know the piston is coming up on the compression stroke.
Old Oct 6, 2009 | 12:56 PM
BRay09's Avatar
BRay09
okay, ill do that before i start pulling things apart today. I didnt know if that would be accurate enough or not. Thanks for all yu help.
Old Oct 6, 2009 | 01:24 PM
lew52's Avatar
lew52
When the piston starts to come up & up feel the air come out its on the comp stroke , then just turn the balencer to TDC . as far as start up goes if your breaking in a new cam follow there specs . Have the timing light hooked up , when it starts you may have to turn the dist to get it to idle , with the spout out set the timing & lock down the dist . Make sure you get the gears lined up good ,cam gear 6 oclok , crank gear 12 oclock . The dots must line up , hope you have a shop manule , good luck ... Lew
Old Oct 7, 2009 | 06:53 PM
BRay09's Avatar
BRay09
Another mistake
THis is my first motor that I have ever built and everything was going fine. Until this weekend trying to finally start it... My question is, and what i didnt do, does it matter if you install a camshaft without having the #1 piston at TDC? Im thinking that it was at the top of the block when building this from the block up, but I am not sure. Id hate to have to tear everything back down int the truck. PLEASE HELP!!!
