331ci stroker kit...
Old Oct 5, 2009 | 02:22 PM
rockher_man's Avatar
rockher_man
Question 331ci stroker kit...
...I "thought" I was all good with the Eagle cast steel crank kit...
However......after much comparison and research...I'm startin'
to scecod-guess myself...and I hate that!!!
Anybody got any thoughts regarding Eagle vs.Scat cast steel stroker crankshafts?
Ya know...just the 9000 series stuff that will roll-on FAST......
This motor will be goin' in my '56 F100...only about 3250 lbs.
More than likely NO 1320-time planned...at least I'm considering "that" for part of the motor design...
Either solid tappet or hyd. tappet cam... not sure yet on that...
But I DO know this...
---wish list---
-Canfield-style Heads....1.94/1.60 valves.
-587/.587 lift 228* duration @.050.
-1.7 roller rockers.
-short duration & wide lobe seperation cam.
-Original '63-'64 260ci-V8 SBF HI-Rise, Dual-Plane Tri Power (3x2)
w/original Holley's 730cfm TOTAL (265/200/265cfm).
-H-beam rods because best for CLEARANCE issues.
-main girdle AND a stud-girdle on the top end.
-I ain't afraid to install a SOLID FLAT TAPPET cam...
Old Oct 5, 2009 | 04:56 PM
rockher_man
OK then...
...thankZ fellaZ...
C ya @ Milan...in the rear-view...
Old Oct 5, 2009 | 08:50 PM
70torino429's Avatar
70torino429
Why on earth would you build a 331 instead of a 347? Unless you want to make less power.
And...i hope you can find the Canfield heads used, because they shut down shop.
Old Oct 11, 2009 | 11:44 AM
8bahead's Avatar
8bahead
Why go through the headaches headbanging ect. contact Jim Woods @ Ford Strokers he offers both scat and eagle balanced rotating assemblys. Check out his short blocks they're worth the money.
john6teen33
16
Apr 22, 2017 11:40 AM
john6teen33
Apr 21, 2017 02:46 PM
rockher_man
Apr 21, 2012 01:18 PM
F-250 restorer
Oct 5, 2010 07:24 PM
1TUFFBRONCO
13
Jun 8, 2004 01:49 AM
