1978 - 1996 Big Bronco
Brake bleed question, replace calipers?
Old Oct 5, 2009 | 01:03 PM
osb's Avatar
osb
I've got a 96 bronco that my son and I are fixing up to be his first ride.
We're working on the brakes, but cant seem to get the bleed complete on the fronts. The bleed nipples are completely frozen into the calipers. I'm tearing them up trying to get them out. (both fronts are in the same shape)
I suspect i could get them out if I remove the calipers and get it on the bench, but if I'm gonna go to that much trouble, should I just replace the calipers at that point, or put a new nipple in ?
Any insight as to why they lock up like that? There's no rust anywhere, and the rears were a piece of cake.
Old Oct 5, 2009 | 03:34 PM
McLeod's Avatar
McLeod
If going to the trouble of disconnecting them, I'd just replace the entire caliper. They aren't that expensive and offer more piece of mind.
Make sure you get a new flexible brake line too.
This piece can cause brake problems when it gets soft.
krewat
Mar 14, 2017 02:12 PM
daveplot
Aug 21, 2015 05:46 AM
texasjack
Mar 15, 2014 07:52 PM
daveplot
May 27, 2013 08:35 PM
Skarr
2004 - 2008 F150
Apr 11, 2008 07:10 PM
