Need Help
Old Oct 5, 2009 | 10:53 AM
mejer1's Avatar
mejer1
Need Help
Hello,
I don't get on this site much but know I can get help here.
I have a 1992 F-150 with the 4.9 six with 240,000 miles. Last thursday nite we got alot of rain. And the truck is outside. It starts fine and runs normaly, then it starts acting like it is missing after about three or four minutes of driving. On sunday I changed the rotor and cap thinking the cap may be cracked, but no change. I also hear a pinging or backfire from the motor.
Please give me any ideas that you think it could be. This is my daily driver and work truck being I am a carpenter.
Thanks John
Old Oct 5, 2009 | 11:40 AM
subford's Avatar
subford
You need to see if you have any codes in CM.
Sounds like you may have a bad TFI module, Map sensor or the PIP sensor going bad.
Old Oct 6, 2009 | 05:35 AM
mejer1's Avatar
mejer1
Thanks for the reply, Also when the truck sits for 20 minutes or so it will run normal for a little while. And when it starts running rough I can smell unburnt gas. I am going to try to get the codes read today.
John
Old Oct 6, 2009 | 07:04 AM
subford's Avatar
subford
You can read the codes yourself, if you do not know how go to one of the links below:
This is good for the KOEO test:
Ford Fuel Injection How To Run a Self-Test
This one is good for the KOER test:
Ford Fuel Injection KOER Test
Or get a code reader, here is a good one.
The EQUUS #3145
Old Oct 6, 2009 | 07:23 AM
jr32560's Avatar
jr32560
I kinda had the same problem was the park plug wires-but mine ran like crap till it dried out?
the coil wire was making a bad connection on the coil and to the cap figured it might help to drop that info in?
fludoc
Jul 31, 2016 07:36 AM
chiefsfootball
13
Jun 27, 2016 11:39 AM
KJNDIVER
61
Jun 2, 2016 08:33 AM
Pdxjacob
May 9, 2016 01:57 PM
six6six
6.4L Power Stroke Diesel
15
May 12, 2015 08:10 AM
