Offroad & 4x4
Dana 80 Trac Loc Rebuild
Old 04-27-2016, 02:20 PM
Rcmgiasson's Avatar
Rcmgiasson
Rcmgiasson is offline
Is there any way to stack or shim the trac loc clutches to make the trac loc more aggressive on these trucks? I've read tons of info on the D80 about a "restack" but most of it applies to Dodge stuff where they have up to 12 plates/clutches per side. The Fords only have 7 and I can't see any logical way to restack them which would change anything.
Factory Order is:
Side Gear
Preload shim
Clutch
Disk
Clutch
Disk
Clutch
Disk
Disk
I also tried adding an old clutch disk between the last 2 disks but it makes the package way to thick to get the case halves together. Anyone have any input besides the usual "swap out for a locker"?
Old 05-15-2016, 09:19 AM
mark a.'s Avatar
mark a.
mark a. is offline
Are you sure it is a "TracLoc" ? not a power-Loc. Either way if you want it to act more aggressive dump the oil, add new and put a lot less limited slip oil in it than is recommended.
Buck268
05-09-2016 02:56 PM
Rcmgiasson
04-30-2016 12:03 AM
psu1xj
08-25-2004 07:54 PM
Frank T
12-11-2003 06:33 AM
johnsonacres
11-11-2003 06:44 PM
Quick Reply: Dana 80 Trac Loc Rebuild
