Sponsored by: Real Truck
Steering "binding"
Old Oct 3, 2009 | 04:09 PM
Es Gee's Avatar
Es Gee
Steering "binding"
2001 F-250 4x4 75k
Replaced steering stabilizer
Had shop pump out and replace PS fluid
Just lubed all suspension/steering zerks
No lift (stock height)
Nitto Terra Grappler 305/55/R20
Virtually impossible to turn steering wheel when slightly moving or sitting still. Little bit of movement once foot is off brake. Taking weight off front end (floor jack), steering is fine lock to lock so there is nothing binding in the steering assembly. Is there a way to "amp up" the power steering? Heavier duty PS pump? A way to help out the vacuum assist? Thanks in advance for any responses
Old Oct 3, 2009 | 06:52 PM
EXv10's Avatar
EXv10
Put a new PS pump in it and check your serpentine belt tension. You should be able to turn lock to lock w/foot off brake.
