Sponsored by: Real Truck
picked this up
Old Oct 4, 2009 | 02:36 PM
freekyFX4's Avatar
freekyFX4
Nice truck!
Old Oct 5, 2009 | 03:15 PM
TRAINHORNMAN's Avatar
TRAINHORNMAN
Originally Posted by Furian
Nice! What size tires do you have on that Super Duty?
42s
Originally Posted by montecarlo31
seems like a reasonable deal. Nice truck good luck with it.
i hope so
Originally Posted by F250racer
Cool rig! Is it the 5spd?
no sir decided to go automatic
Originally Posted by ford7379trucks
sweet. should have got a pic of the cop next to it.
that woulda been funny
Originally Posted by Fordfanatic4life
those stacked big blocks in the rear scare the hell out me...
esp. with the size of tires ur running...
why so
woow ya didnt notice that. get those blocks out of there.
whys that.. someone told me that they are in there pretty good
Originally Posted by XPLOSIV
Trainhornman,
Here's some info and if you want to change them OUO has a good solution. If not, don't worry, you won't burst in to flames.
http://www.oneupoffroad.com/images/O...stem_Intro.pdf
what exactly is this.. i only kno a limited amount of info
Old Oct 5, 2009 | 03:17 PM
TRAINHORNMAN
this forum is soooo much better than the damn diesel stop..*******s over there.. i said damn and got a warning? i didnt know we had wanring of forums..
anyways ill be on this FORUm alot more
Old Oct 5, 2009 | 04:39 PM
BIGBEAR6's Avatar
BIGBEAR6
Did the motor get changed? The badge on the fender says V10
Old Oct 5, 2009 | 05:49 PM
mstiles19's Avatar
mstiles19
stacking blocks is a huge no no..... when they are stacked the probability of one shooting out and killing someone or wrecking your rig is increased. Honestly I personally would never put in blocks over 4 inches.
Old Oct 5, 2009 | 07:24 PM
Furian's Avatar
Furian
You Keep What You Kill
You have some liberty here at FTE but you can receive warnings... I know. I received my first warning (2 points) last December. So, keep it in check.
Old Oct 5, 2009 | 07:25 PM
Furian's Avatar
Furian
I agree! I would prefer no blocks at all.
Old Oct 5, 2009 | 07:30 PM
Fordfanatic4life's Avatar
Fordfanatic4life
with ur truck being a diesel its gunna put even more load on those U-bolts, the leverage placed on them is bad enuf with a single 4" block..
stack em ontop of each other and it really stress's the Ubolt/spring perch out..
seriously its a dangerous practise, esp stacking blocks of the size ur truck has..
get a set of replacement spring and remove the blocks completly or at the very least go down to a single block...
Old Oct 5, 2009 | 08:39 PM
wizardsr's Avatar
wizardsr
Looks like an early 99 powerstroke badge to me...
Old Oct 5, 2009 | 08:48 PM
TRAINHORNMAN
i really dont wanna loose the lift..so what exactly do i need to do? and no its not a v10 it does say v8 its a weird badge
Old Oct 5, 2009 | 09:01 PM
jake00's Avatar
jake00
you can either replace the block (and spring) with a larger spring, or get a 1 piece block
Old Oct 5, 2009 | 09:02 PM
TRAINHORNMAN
any links?
Old Oct 5, 2009 | 10:24 PM
  #28
mstiles19's Avatar
mstiles19
any links?
if you want something cheap i would contact possibly rough country since they do have a really good customer support and see if they will sell you individual springs. I would seriously try to use the smallest block possible if not eliminating it all the way.
Suspension Lift Kits, Body Lifts, Leveling Kit, 4x4, Jeep, Chevy, Dodge, Ford, Off-road Truck
Old Oct 5, 2009 | 10:26 PM
  #29
TRAINHORNMAN
i will try and check tommorw
Old Oct 6, 2009 | 01:34 PM
  #30
Furian's Avatar
Furian
Measure the height of the combined blocks and post up. I'll spend some time finding you an alternative single block of the same height. This will be less expensive and easier to install than new rear springs.
