Sponsored by: Real Truck
crapiola steering stabilizer?
Old Oct 2, 2009 | 11:36 PM
bayou barataria's Avatar
bayou barataria
Hey guys, have a 2008 250 cc lb 2wd with 15,000 miles and am having a slight issue. I replaced the front brake pads a few months ago and some times when I brake the steering wheel will shimmy like I have a warped rotor, or pull one way or another slightly. It did not do this until I replaced the pads, is that the stock steering stabilizer weakening or what? I also have replaced the shocks with kyb h.d.'s on the front and bilstiens on the back when I bought it. The truck is loaded, but well within the specs, about 9500 lbs. total. I also get a slight bounce when braking sometimes, like a frame flex or something, but not anything serious. Have had a lot of trucks over the years, but this is my first cc lb, maybe this is normal? Any feed back would be appreciated. I looked for a bilstien stabilizer, but don't think they make one for this application. I know it is late now, will check back in a day or two. Enjoy your weekend, maybe you are finally getting some nice fall weather like we are here, may try some fishing tommorow.
Old Oct 3, 2009 | 11:03 PM
rudedogii's Avatar
rudedogii
I would first check the front suspension ball joints, wheel bearings, and tie rods for ware.
I ran my 2000 with no stablizer for a week with no problems. Thats with a an 8inch lift and 40inch tires.
I cant beleive you had to replace the front pads at 15,000 miles! Maybe you do have a bad rotor.
Old Oct 4, 2009 | 05:44 PM
bayou barataria
The brakes were not worn out, they were squealing form being wet in the flood last year. The rotors are worn some but don't think they are warped, it is an intermittent problem.
Old Oct 4, 2009 | 06:23 PM
rudedogii's Avatar
rudedogii
Flood!
I would defenately check the hubs and wheel bearings. Water may have gotten in the bearings.
Old Oct 4, 2009 | 08:20 PM
bayou barataria
This is a 2wd.
