04 - 6.0 Hard Start "HELP"
Old Oct 2, 2009 | 08:25 AM
dmanser's Avatar
dmanser
Hi,fficeffice" /><O></O>
I have a 04- F250 w/ 6.0 115K and I live in CA were the weather is not that cold in the mornings maybe 59dg. When you start it in the morning it fires then dies, start again fires & dies, start again no fire, start fires and runs great no loose of power. The rest of the day, no problems. I have scanned it and there are no codes coming up. So I took it to a shop that only works on diesels trucks, they kept it over night and started it, the same thing. They did find low oil pressure going to the right bank, so they changed the oil feeder tube, same thing, next removed the injectors and had them tested found a very small leaks so we had them rebuilt, (Ford just replaced all the injectors turbo and EGR at 99K under warranty).<O></O>
We still have th same problems no change at all. Now they can't figure this out, I'm thinking the HI pressure pump or pressure sensor?? Any Ideas? I'm in to this for about 1500. with no results and need to see the end soon!! Thanks<O></O>
Old Apr 16, 2010 | 11:19 AM
firemedic116's Avatar
firemedic116
clean your egr yourself and make sure they didnt leave trash that got caught back up in the seat of the egr.
Old Apr 16, 2010 | 09:02 PM
Zmann's Avatar
Zmann
the op is old
