General Automotive Discussion
Rust Reformer?
Old Oct 2, 2009 | 06:38 AM
Bruker's Avatar
Bruker
Question Rust Reformer?
Has anyone here ever used Rustoleum (or other brand) Rust Reformer?
I have an `03 Ranger that's starting to show some rust in the area of the bottom door and tailgate seams that I'm going to give this stuff a try on. Just thought I'd see what others experience was. Thanks!
Old Oct 2, 2009 | 02:29 PM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
I have used a rust converter called Conquest. It works really well. You only have to remove any loose rust or flaking. I give it two or three days to dry as it is water soluable and I'm usually using it under oil base paint. Once it cures, it turns black. Always primer it first but if you try to cover it with white, you may need a stain blocker like Kilz.
Let us know how the Rustoleum works out. I might decide to try it. Does it come in cans, spray can or both?
Old Oct 2, 2009 | 07:28 PM
shorebird's Avatar
shorebird
Get some Ospho rust converter. I used it when I worked as a welder.
"HOW SKYCO OSPHO WORKS
When applied to rusted surfaces, it resists/retards rust in chemical change on drying to a tough, hard surface ready for priming. A paint job will last longer after an application of OSPHO because subsequent paint coating securely attaches itself so that moisture and oxygen normally do not attack the metal. OSPHO is water-thin, can cover a larger area than paint, and goes on easily. It is equally effective for exterior and interior work alike. SKYCO OSPHO: a balanced formula of Phosphoric, Dichromate, Wetting Agents and Extenders . . . compounded exclusively by the Skybryte Company since 1947 ... recommended by paint manufacturers."
Old Oct 2, 2009 | 07:55 PM
bodabdan's Avatar
bodabdan
Veteran: Navy
OSPHO here too.
Old Oct 6, 2009 | 09:43 AM
jimandmandy's Avatar
jimandmandy
I also use Ospho. Be aware that it is slow to dry, stains concrete and does contain chromium, which is a terrific corrosion inhibitor, but is toxic.
Jim
GaryKip
Nov 16, 2016 09:14 PM
fabieber
Mar 30, 2016 10:42 PM
annaleigh
Oct 24, 2015 06:16 PM
plowboy1986
13
Oct 2, 2012 05:34 AM
Downriver Thunder
Dec 8, 2008 12:20 PM
