oil pump drive
Old Oct 1, 2009 | 09:20 PM
f250red's Avatar
f250red
oil pump drive
I know it has probbly been posted before but I need to know if the hex shaft between the dist. and oil pump goes in the 292Y with the snap ring on the top or bottom. thanks F250 Red
Old Oct 2, 2009 | 06:18 AM
BlueOvalRage's Avatar
BlueOvalRage
Red,
I don't know squat about Y-blocks, but on a Windsor smallblock, the shaft is inserted in the oil pump with the clip up away from the pump and then the two are bolted to the block. The idea is that the clip will bottom against the block when you pull the distributor out at a later date and keep the shaft from pulling out of the oil pump and getting dropped into the pan. Perhaps the Y-block setup is similar.
