Is it Worth It?
Old Oct 5, 2009 | 02:44 AM
txmnjim's Avatar
txmnjim
Originally Posted by 300 Buster
Jim, I'm from Michigan,When you let an old truck sit a couple years up here,the underside looks like it has rust barnicles .Just a quick tip for everyone,if you leave a vehicle set for a length of time,put a tarp under it,it keeps ground moisture from wetting the bottom all the time.If you lay a piece of plastic bag in your yard overnight,the next day,the underside will be covered with moisture,same thing happens to you vehicle.
Good tip Buster! Thanks a lot.
Jim
