Engine burping
Old Sep 30, 2009 | 07:41 AM
bulldogcountry1's Avatar
bulldogcountry1
Engine burping
I've got a 78 F250 with the 400 in it. For the past 4 years (after I got a new engine), I've had an Edelbrock 750cfm on it. I decided to change to a 600cfm to get some better mileage and improve daily driveability, so I put the Edelbrock version on.
When the truck is cold, and I'm trying to accelerate at light throttle, it burps out into the headers and loses power, but it doesn't backfire out of the exhaust pipes. If I give it more gas and try to accelerate at medium (or higher) throttle, it seems to bypass the problem and doesn't do it.
I have an air/fuel meter (the cheap variety with the lighted bars), and it's showing a slight rich condition, which is what it shows at cruise. So, that seems fine.
Any ideas?
Old Oct 3, 2009 | 08:27 AM
doug1222556's Avatar
doug1222556
Check the linkage to the accelerator pump. You may need to bend that rod to get the proper operation.
Old Oct 7, 2009 | 10:31 AM
bulldogcountry1
The pump linkage has 3 holes, and I moved it to the more "rich" hole, and it doesn't do it as much, but still does until the engine heats up.
I checked the fuel pressure, and it's about 5 psi. I think Edelbrock recommends 5-6 for those carbs. Could that be a problem?
The truck cranks up fast and runs great otherwise, so I'm pretty confused.
Old Oct 7, 2009 | 11:19 AM
doug1222556
Does it have an electric choke? If so you may need to adjust it. It's starting to sound like a choke that's not opening up soon enough.
Old Oct 7, 2009 | 10:30 PM
Mustang6147's Avatar
Mustang6147
It kind of sounds like you distributer isnt advanceing. If you have vacuum advance, make sure it is functioning properly, if you have weights to, check them....
Keep in mind, a rich mixture, when hitting cold air, may rumble a bit, or pop even.
MontanaboyDesigns
Feb 22, 2017 03:25 PM
AirCav
21
Jun 22, 2015 04:04 PM
paddler
Apr 6, 2009 03:04 PM
dlowenst
18
Oct 11, 2006 10:14 AM
Longbed 68
Jan 23, 2004 11:18 PM
