1978 - 1996 Big Bronco
curb idle good in gear idle bad
Old 09-29-2009, 12:30 PM
spuds0828's Avatar
spuds0828
spuds0828 is offline
Hello all I need some help does anyone know where i can find a vacuum diagram for a 1985 bronco 4x4 351 windsor h.o. 5.8L i am having some trouble with my idle i have good curb idle but when i put it in gear it feels like it wants to bog out it sounds like a vacuum leak but i cant find it i have tried the carb cleaner trick and found 1 but thats taken care of now so now im on to find out whats next. i also removed the smog pump so the cross member pipe that connected the heads is wide open could this have anything to do with it????? please help if you can
Old 09-29-2009, 03:07 PM
Kemicalburns's Avatar
Kemicalburns
Kemicalburns is offline
the back of heads needs plugged up for sure.
Old 09-30-2009, 12:26 AM
g_k50's Avatar
g_k50
g_k50 is offline
Should be a vacuum diagram for emission control in the engine compartment. Have you rebuilt and adjusted the carb?
Greyf100
04-21-2012 06:40 PM
4caster
08-09-2009 04:43 AM
enskpo
02-05-2006 10:27 PM
tombob
03-02-2003 11:21 PM
jcheyn
01-23-2000 08:45 AM
Quick Reply: curb idle good in gear idle bad
