Need help finding right gasket set
Old Sep 30, 2009 | 09:20 PM
superd02's Avatar
superd02
Originally Posted by Jeremy Ruppert
So what engine was put in the F100/350 before the 351M?
Jeremy
in a 4x4 - the 300 the 360 and i dont know if the 302 was ever in a 4x4
in a 2x4 the 300, 302, 360/390 and the 460
Old Oct 1, 2009 | 01:47 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1959 was the first year Ford offered factory installed 4WD.
1959/60 F100/250 4WD: 223 I-6 / 292 2V.
1961/64 F100/250 4WD: 223 & 262 I-6's / 292 2V.
1965/67 F100/250 4WD: 240 & 300 I-6's / 352 2V.
1968/74 F100/250 4WD: 240 & 300 I-6's / 360 2V.
1975/76 F100/150/250 4WD: 300 I-6 / 360 2V.
1977/78 F150/250 4WD: 300 I-6 / 351M/400.
1979 F150/250/350 4WD: 300 I-6 / 351M/400.
No factory F350 4WD's until 1979. No 460 4WD's until 1983.
The only 4WD vehicles prior to 1980 that had 302 engines were 1969/77 Bronco's.
1978/79 Bronco: 351M/400.
1959/79 F100/350 2WD:
1959/60 F100/350 2WD: 223 I-6 / 292 2V.
1961/64 F100/350 2WD: 223 & 262 I-6's / 292 2V.
1965/67 F100/350 2WD: 240 & 300 I-6's / 352 2V.
1968/72 F100/350 2WD: 240 & 300 I-6's / 302 (1969/72 F100 only) / 360 2V / 390 2V.
1973/74 F100/350 2WD: 240 & 300 I-6's / 302 (1973/74 F100 only) / 360 2V / 390 2V / 390 4V (1974 only) / 460 4V.
1975/76 F100/150/250/350 2WD: 300 I-6 / 302 (1975/76 F100/150 only) / 360 2V / 390 2V / 390 4V / 460 4V.
1977/79 F100/150/250/350 2WD: 300 I-6 / 302 (F100/150 only) / 351M/400 / 460 4V.
Old Oct 1, 2009 | 12:40 PM
Jeremy Ruppert's Avatar
Jeremy Ruppert
Im not sure if my truck is a highboy but heres a pic of it in its current condition. It has had a 79 F150 box and cab swapped on but im not sure on the year of the frame.
DSC04396.jpg picture by jruppert - Photobucket
DSC04387.jpg picture by jruppert - Photobucket
Old Oct 1, 2009 | 01:14 PM
NumberDummy
The bed is 1977/79 as it has a fuel door.
1973/76 beds have exposed gas caps.
It's kinda hard to make out in the pic, but it appears the cab has/had an in-cab fuel tank. This type of tank was no longer used after midyear 1977.
From what I see, it a 1977 F250 4WD (High Boy), High Boys were only made from 1973 thru midyear 1977.
Old Oct 1, 2009 | 01:18 PM
Jeremy Ruppert
I think the cab is a 77/79 as well because someone hacked through the cab to make a hole for the in-cab tank, it wasnt originally that way. It looks factory in the picture. Plus it has 77/79 style headlights.
Jeremy
Old Oct 1, 2009 | 01:28 PM
NumberDummy
Jeremy
Late 1977's and 1978/79 cabs do not have an in-cab fuel tank.
There is no such thing as 1977/79 headlamps.
1978/79's have a different grille and headlamp/parking lamps than 1973/77's.
1973/77's use the same grille shell, all have round headlamps.
Some 1978's have round headlamps, all Rangers, Ranger XLT's and Lariats have rectangular headlamps.
Most 1979's have rectangular headlamps except for stripper Custom's sold as fleet vehicles (to the gov't, airlines, construction co's, and etc) that have round headlamps.
Old Oct 1, 2009 | 02:29 PM
Jermafenser's Avatar
Jermafenser
The cab is 78/79 as it has the plastic steering column cover. If it has an in-cab gas tank, it was hacked in.
Frame VIN question: It is on the top. It could be anywhere between the firewall and the core support. Clean it really well.
Old Oct 1, 2009 | 02:32 PM
Jermafenser
IIRC, Ford made a running change in spring of 1978 to discontinue round headlamps. Indeed, only the Custom trim was available with the round headlamps. Ranger, XLT, and Lariat all got rectangular headlamps.
All late '78s and '79s had rectangular headlamps.
Old Oct 1, 2009 | 02:42 PM
NumberDummy
I had the American Airlines parts account for nearly 30 years.
Next time you're at LAX, look round for their dark blue trucks.
They are still using 1970's trucks, have several stripper 1979 Customs...with round headlamps.
Your parts catalog lists round headlamps for 1978's & 1979's.
Old Oct 1, 2009 | 03:51 PM
Jermafenser
It's only what I remember when I was a dealer for a defunct Ford/Mercury/Lincoln franchise then. I think there was a bulletin on them. Not the best place I've worked at, anyhow. I think it was kind of silly to have both types of headlamps.
But I do want look it up for future reference. What group are the headlamp surrounds in?
Sadly (or not), I have never been to the LAX.
Old Oct 2, 2009 | 01:00 AM
NumberDummy
13008 = headlamp assemblies
13064 = headlamp bezels.
I've been to Baltimore, WA National, Dulles, but never to the eastern shore of Maryland...or to Delaware, either. Been everywhere else on the east coast.
rustyruststang50
Mar 5, 2014 09:13 PM
99F250Iowa
Modular V8 (4.6L, 5.4L)
Nov 19, 2010 01:27 PM
the grimlin
Feb 18, 2008 04:46 AM
