New to the forums..
Old Sep 28, 2009 | 11:21 AM
d3v1l08's Avatar
d3v1l08
New to the forums..
Just wanted to drop in and say hello. I'm new to the Ford family. I just traded a 1996 Mazda Mx-6 5 speed w/ 177k for a 1994 F250 7.3 (Non-Turbo) w/ 150k. Truck is in pretty good shape. The bed is a little beat up, but nothing I can't deal with. My problems are: the drivers front tire hits the bumper when urning right, the truck seems to surge while driving doen the highway (rpms go up and down, then level out), it died while driving home yesterday (not sure why), and the tranny shifts so hard it feels like a kick in the back.
Any ideas?
Chris
Old Sep 28, 2009 | 12:09 PM
Lazy K's Avatar
Lazy K
There is a page here devoted to your engine. If you go on down the main forum page to the diesel section you will see the page for the pre-power stroke diesels. Great guys there.
However the surging problem is usually due to a fuel delivery problem, either air intrusion in the fuel system or weak fuel flow. May also explain the stalling.
The first thing I would do is fit a new fuel filter. Fill the new filter with something like Diesel Kleen before you fit it and toss any left into the fuel tank.
For more info post this on the pre-power stroke page.
As for the trans are your speedo and tach working?
Old Sep 28, 2009 | 12:52 PM
d3v1l08's Avatar
d3v1l08
The speedo seems to work, but it feels like the truck is running slower than the speedo. The tach works intermitant. If i rev too hard the tach will hang around 4000 rpms. once it shifts and revs over 3000 it will catch up and be on the right rpm.
Old Sep 28, 2009 | 02:28 PM
Lazy K's Avatar
Lazy K
Just to be clear is your trans a 3 speed (C6) or the overdrive trans with the O/D button (E4OD)?
Old Sep 28, 2009 | 03:14 PM
d3v1l08's Avatar
d3v1l08
I believe its the 4 speed. It has O/D on the dash next to park and neutral.
Old Sep 28, 2009 | 03:16 PM
bigmacmonday's Avatar
bigmacmonday
mkay you got the e4od then
Old Sep 28, 2009 | 09:46 PM
d3v1l08's Avatar
d3v1l08
So, any ideas? Do ineed a new tach??
Old Sep 28, 2009 | 09:49 PM
quicklook2's Avatar
quicklook2
the vss may be the problem or the psom on the instrument cluster.
Old Sep 28, 2009 | 09:52 PM
d3v1l08's Avatar
d3v1l08
the who?? on the what? Sorry, complete noob.. vss = vehicle speed sensor. psom = ?
How much are they?
Old Sep 28, 2009 | 10:14 PM
quicklook2's Avatar
quicklook2
vehicle speed sensor, on rear end.
programmable speed o m, forgot what o m means.
on back of gauges.
Old Sep 28, 2009 | 10:21 PM
d3v1l08's Avatar
d3v1l08
how do i test them? Sorry for asking so many questions
Old Sep 29, 2009 | 06:54 AM
Lazy K's Avatar
Lazy K
Your engine is governed to 3400revs so I would think the tach is not reading right.
Look at the front of the engine beside the oil filler cap and you should see a large hex nut with wires coming out of it. That is the tach sensor. Unscrew it, clean it and check closely the condition of the wires. If good replace it and see if it now works.
Old Sep 29, 2009 | 03:27 PM
d3v1l08's Avatar
d3v1l08
Awesome. I'll try that. What about the Vehicle speed sensor?
Old Sep 29, 2009 | 03:39 PM
Roger T. Pipe's Avatar
Roger T. Pipe
Your VSS is located on top of the rear end center section. I recently had a problem with mine (incorrect speedo reading) & swapped it out and it works fine. I used a junkyard part, but I'm pretty sure these don't run you more than 40.00 or so. Welcome to the madness, BTW!
Roger
Old Sep 29, 2009 | 10:44 PM
d3v1l08's Avatar
d3v1l08
No luck with the Engine speed sensor. Still not registering the rpms very often. I cleaned it off but no luck.. i guess i'll try a junk yard and se what i get. Anything else i can check?
