grounding
Old Sep 30, 2009 | 04:08 PM
rebelchevy02's Avatar
rebelchevy02
Couple more things.
1 When was your last oil change? (miles/approximate month if its been a while)
2 You may consider unhooking your ICP sensor wire from the ICP sensor. And seeing what that does. I think your at the point were we are going to need some diagnostic information from the truck.
Old Oct 2, 2009 | 09:20 AM
renchr56's Avatar
renchr56
oil change was done 100 miles ago. I just checked all glow plugs and all are working. I also did compression test and all are 450 except 1 and it is 650.. Now I will connect everything back up and pull the icp sensor connector off and see what that does. As far as everything else goes there are no codes.
Old Oct 4, 2009 | 01:47 PM
rebelchevy02
Any updates?
Old Oct 5, 2009 | 06:33 AM
renchr56's Avatar
renchr56
No updates as of yet. Been off whole weekend. Much needed I might add. Will advise when I find anything out
Old Oct 5, 2009 | 07:05 AM
renchr56's Avatar
renchr56
well just tried to start the truck after sitting the weekend. Still has hard start problem. I disconnected the ICP and still same problem. but when I get it to start I have no throttle response.
