Egr ?
Old Sep 27, 2009 | 11:42 PM
ronnyferrell's Avatar
ronnyferrell
Egr ?
I bought a 1998 ranger 4.0 L with no moter. I picted up a moter from a 2000 ranger 4.0 L. well the new moter does not have a EGR valve there is just a plug in the exuast where there should be an EGR valve. there also is no EGR Valve Pressure Sensor nor is there a wire for the EGR Valve Pressure Sensor. Im thinking i need a wire harness from a 1998 Ranger 4.0 L to hook up this EGR valveto get the Check Engine light to go away and so I can get it to pass smog
Any help would be appreciated
Thank you
Old Sep 28, 2009 | 02:10 PM
Franklin2's Avatar
Franklin2
You are correct. You need the harness and computer if your 98 doesn't have it, as well as all the sensors and engine dress from a 98 ranger if the 2000 engine is that much different.
