Stock Fuel Pump Limits
Old Sep 27, 2009 | 11:34 PM
wantaford's Avatar
wantaford
Any one with knowledge on a 460 EFI setup know with the stock fuel pump(s) what max horsepower they are capable of?
I am contemplating upgrading to 30 or 32 lb injectors. I have added a few external mods and am getting close to being ready to take it to my local dyno tuner to have the ECM reflashed and calibrated. I have a MAF system. I don't have the luxury of having any cheap tuners around me, they charge $400+ for each dyno/calibration appointment. So I want to make the first one count.
I really don't want to upgrade the fuel pumps, so if the stock pumps can supply 30 or 32 lb injectors I will do it. If any one know's please respond - thanks!
Old Sep 28, 2009 | 08:11 AM
Conanski's Avatar
Conanski
Unless the motor moves a lot more air than stock you're wasting your time and money with bigger injectors, the stock 24/s will support 300hp at 80% duty cycle, 325hp at 85%, etc. If your motor is up past that mark I sugget you simply get a MAF meter that is "calibrated" for 30lb injectors, there's a pretty good chance the dyno tuner will do the exact same thing as what the meter does... i.e. tweak the MAF curve.
As for the fuel pumps they won't support the full capacity of 30lb injectors, that will require at least 155l/hr pumps. Stock is around 110l/hr.
Old Sep 28, 2009 | 09:52 AM
wantaford's Avatar
wantaford
I have upgraded the intake duct work. I have a open element K&N filter with a custom made cold air dam hooked to a 85mm Pro-M MAF running through 3.5" tube to a splitter. From the splitter it is 2.5" ducting to a dual 61mm BBK Throttlebody that is port matched with the inkake plenum elbow (because the ports didn't exactly line up with the Ford intake elbow). Then on the exhaust side it is Banks Headers with a Eastern Catalytic Performance Cat and 4" tail pipe. So I am incheck for the intake and exhaust flow. I have new fuel pumps and an adjustable fuel pressure regulator.
I just don't want to get to the tuner and he says after the dyno, something like "now all you need is 30-32 lb injectors and we can get you X-more horespower". I don't want to hear that after forking out $400 bones. So to hear that my stock fuel pump won't support any bigger injectors is frustrating but reality.
Old Jan 23, 2010 | 01:08 AM
wantaford's Avatar
wantaford
Anyone seen any vendors offering hi-performance fuel pumps? I would like to upsize my injectors and will need to reflash the ECM upon completion. Checked around and only finding stockers for F-series.
Old Jan 23, 2010 | 10:47 AM
Conanski's Avatar
Conanski
I suggest you invest your money in an electric fuel pressure gauge and a wideband O2 sensor. With those things you will be able to determine with certainty if you have enough fuel pump and injector capacity. The diagnosos is simple..
If fuel pressure drops at rpms you don't have enough pump.
If pressure stays solid and A/F ratio goes lean at rpm you need bigger injectors.
If pressure stays solid and A/F stays rich(12.5-13.5:1) then you don't need either.
Old Jan 23, 2010 | 03:01 PM
BigBlueOx's Avatar
BigBlueOx
Although I think your stock fuel pump will handle the load of 32 lb injectors and your setup, I totally agree with this post.
Old Jan 23, 2010 | 03:19 PM
Conanski's Avatar
Conanski
Here's a calculator for fuel pump and injector sizing... Autolounge.net | Calculators | Fuel Injector and Pump Sizing
All the default values are good so just insert the HP number you want and you'll see what it requires. I think it will take more than a free flowing intake and exhaust to exceed 300hp with an otherwise stock 460, and the computer will push the injectors all the way to 100% if it needs to so the pump will be the first limitation you run into. You can also extend the capacity of the injectors by increasing the fuel pressure.
Old Jan 23, 2010 | 03:31 PM
lew52's Avatar
lew52
X 2 on the fuel pressure gauge & wideband , its not how big the injectors are its how much air & fuel your pushing thru the motor...Lew
Old Jan 23, 2010 | 11:16 PM
4wheeling79's Avatar
4wheeling79
You definetly need a O2 wide band and to moniter your fuel pressure. I didn't see that you had any internal engine work done that would require more fuel. I'm not sure exactly what the stock fuel pumps can support or what they flow exactly. But with my mods i am running the stock fuel pumps and 36# injectors they are a tad to much but they where free and i just toned them down with my programmer. I would say your are pretty safe still with the 24# injectors they are probably working at about 80-85% duty a WOT. Lets see those dyno #'s
Old Jan 24, 2010 | 03:48 AM
wantaford's Avatar
wantaford
That Autolounge Calculator is awesome - thanks for sharing.
I would be satisfied at 350 horse. Would like to get to 375 though. I have an adjustable fuel pressure regulator now. I only have it set at 34psi. Not sure how much I can really turn it up without having issues. If the stock pumps flow 110 gph then it will support up to the horsepower goal with a tweek of the fuel pressure reg. It will support 350 horse at 34 psi on 24lb injectors per the calculator at 80% duty cycle.
With the necessary internal engine mods, 375 horse looks like it is doable at 35 psi but would require bigger injectors. No chance of ever pushing more horse without bigger fuel pumps.
Still need a good dyno/calibration re-flash. Have not done that investment yet because not sure what to do long term with this powertrain. Getting really tired of watching the diesels pass me up on 6-7% grades. Thinking about overhaulling the 460 with some good internal upgrades or doing a 12-Valve 6BT Cummins Conversion. Not sure where to go, I can buy a lot of gas for the price of the Cummins swap.
Old Jan 24, 2010 | 09:33 AM
Conanski's Avatar
Conanski
What's with the 34psi fuel pressure? It should be 43psi when vacuum is removed from the regulator.
Old Jan 24, 2010 | 11:24 AM
wantaford's Avatar
wantaford
Hmm, it's been a while since I checked it. I checked my Ford manual this morning, it says 30-45 psi. I remember with my stock regulator I was less than 30 psi (like 28) on new fuel pumps (KOER). I installed the Adjustable to get the pressure up to spec but was being conservative on the pressure. I know I put it at spec but I was conservative on the pressure. I am pretty sure I set it at 34 or 35 PSI, Vac Line removed - engine running. Per the Ford Manual:
"TRUCK ENGINES Engine Mode Engine Application
All Applications
ENGINE RUNNING 30—45 PSI
210—310 kPa
KEY ON, ENGINE OFF 35—45 PSI
240—310 kPa
Note: Maximum fuel pressure is obtainable at WOT or the vacuum hose removed from the fuel pressure regulator".
Conanski, I know I don't completely understand EFI - but my limited understanding led me to believe more pressure = more horsepower, but also worse fuel economy. Thus my conservative pressure at 34 psi engine running. Am I wrong in this thinking? Are you making that adjustment at Engine Off or On?
Old Jan 24, 2010 | 11:58 AM
BigBlueOx's Avatar
BigBlueOx
High fuel pressure is not nessisary to make more HP. Bigger injectors, flash, and engine mods are.
Old Jan 24, 2010 | 12:33 PM
Bovaloe's Avatar
Bovaloe
Not trying to hijack here, but can you use a single inline pump to boost fuel pressure so as not to have to replace the 2 in tank pumps?
Old Jan 24, 2010 | 12:49 PM
BigBlueOx's Avatar
BigBlueOx
I've done that on my 6 cylinder Audi with 60# injectors. I have the stock tank pump then an extra boost pump( walbro )
just keep the boost pump before the fuel filter.
