Sponsored by: Auxito
Sparkplug Wars
Old Sep 27, 2009 | 08:34 PM
Windsorman's Avatar
Windsorman
Sparkplug Wars
I read several of the threads about blown sparkplugs in the Ford Triton engine. I have a 2003 Ford f150 4x4 with the 5.4 engine and 65,000 miles. I decided to check and replace the plugs before the 100,000 mile recommended interval. The engine was cold when I performed the work. I found 7 of the plugs in good shape. One plug had signs of early failure. The #4 piston (passenger side rear cyclinder). Also, the hardest to reach of course. The plug had obvious carbon scoring above the threads from what I assume was blow by. The plug was not in as tight as the others. I am the orginal owner of this truck and these were the factory plugs. I put in new plugs along with a little anti-sieze. The spark plug threads in the #4 cylinder felt pretty tight and I was able to cinch up the new plug. Did I divert disaster or is time ticking? Has anyone had the same experience?
Old Sep 27, 2009 | 09:05 PM
torkum's Avatar
torkum
If you have a mid year build on the engine, thats when Ford added threads to the heads.
As for the #4, might have had moister in the hole. Does your heater hoses leak?
Old Sep 27, 2009 | 09:06 PM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD
You should be just fine. I think the plug blowout problem was resolved with the 02 and newer heads.
Sounds like your good to go to me.
Nice work sir!!!!
Old Sep 27, 2009 | 09:44 PM
Windsorman's Avatar
Windsorman
Thanks for your input. The engine build date is 1-31-2003 according to the tag, so I might have the shallow thread design on the cylinder head. I have not had any coolant leaks with this engine. The substance on the old plug is black and powdery like carbon. The electrode is not fouled, so I am still thinking along the lines of a small gas leak. I noted that the sealing ring on the spark plug has small erosions. The COP boot is not heat damaged, but had a light off color.
Old Sep 28, 2009 | 10:35 PM
vista461's Avatar
vista461
I wish I had done that Mine blew out at 101,000
Used a timesert kit and have 40K more spark plug trouble free miles.
georgiaboy79
1997 - 2003 F150
Sep 9, 2014 09:11 AM
MWH615
Mar 2, 2010 11:32 AM
T18skyguy
Modular V10 (6.8l)
Jan 14, 2008 05:20 PM
UncleRedBuck
Modular V8 (4.6L, 5.4L)
Nov 5, 2007 04:04 PM
barneymc
Modular V10 (6.8l)
Aug 22, 2007 05:46 PM
