302 bellhousing pattern Q
Old Sep 27, 2009 | 09:53 AM
J1MMY's Avatar
J1MMY
Can someone clear this up for me please...
302 (D4DE) with a C6 mounted up. C6 has an integral bellhousing.
Will I be able to mount a C4 onto the C6's bellhousing pattern? If so, what else can be bolted to it?
Old Sep 27, 2009 | 10:39 AM
Conanski's Avatar
Conanski
Any small block tranny will bolt up, C4, C6, AOD, 4R70W, and E4OD.. last 2 are electronically controlled. You could also attach the small block M5OD and ZF 5-speed manuals plus any of the older T series with a small block belhousing.
Old Sep 27, 2009 | 11:35 AM
J1MMY's Avatar
J1MMY
Thanks Conanski, some idiot was trying to tell me that because I have a C6 bolted up I must have the wrong pattern on the block for changing to another trans because.....C6's were only built for Big blocks
Old Sep 27, 2009 | 03:45 PM
Conanski's Avatar
Conanski
Ahh well.. you're over across the pond and you can't expect those guys to know a whole lot about the north american products.
Old Sep 28, 2009 | 10:41 AM
TigerDan's Avatar
TigerDan
Gosh, then you and I both have something that those guys say doesn't exist, as I have a C6 with the small block pattern as well...
They were usually found in vans and trucks behind a 351W, but could also be found behind a 351C in some applications. The one I have came out of a Ranchero GT...
19-F250-78
15
Feb 16, 2013 03:25 PM
95Ford4x4
Dec 12, 2006 10:47 PM
390fe
May 17, 2006 02:16 PM
stats2me
Nov 4, 2005 08:26 AM
edward
Nov 26, 1999 09:50 PM
