a/c blower motor problem
Old Sep 27, 2009 | 01:26 AM
knitebee's Avatar
knitebee
I've got an '83 F150 with factory A/C. For some time now when ever the heater selection switch is on A/C or any setting that cycles the A/C (defrost, mix) the blower motor will start bogging down after its been running for 20-30min. If I kick the selector over to "vent" or "heat" setting the fan will be back up to speed within a minute or two. The resistor pack test good. Being an issue that doesn't start tell its been running for a while has made it very incovienent to try and diagnose the cause. Any ideas of what to test and how?
Brian
Old Sep 27, 2009 | 08:54 AM
Brooksd1991's Avatar
Brooksd1991
sounds like your blower is going out. It still has a little life left, but they arent too expensive and if you dont wanna waste your money plenty of salvages have them.
Old Sep 29, 2009 | 12:02 PM
knitebee's Avatar
knitebee
#1 I just replaced the blower motor and the problem is the same.
#2 the problem is only there on a setting that engages the A/C
Old Sep 29, 2009 | 12:19 PM
1986F150six's Avatar
1986F150six
Is it possible that the evaporator core is icing up, thereby restricting the air flow?
Old Sep 29, 2009 | 03:14 PM
knitebee's Avatar
knitebee
Certain that isn't the case, you can even hear the blower motor bogging down. Of course ever time I drive far enough to have the issue I either dont have the time or volt meter with me to get more info.
