302 Identification
Old Sep 27, 2009 | 01:00 AM
davewave649's Avatar
davewave649
302 Identification
I know the the engine in my 1963 F100 came from another vehicle, (i think a mustang) is there any way to identify the engine to get an idea of what year it is from?
Old Sep 27, 2009 | 10:45 AM
Conanski's Avatar
Conanski
Not really unless there is an original tag hanging from one of the intake bolts or sticker on one of the valve covers. You can get some basic info from the casting numbers, the block numbers are down by the starter and the head numbers are on the head gasket side. But those won't tell you much about what vehicle the motor was built for, the cam lift and duration would say more about that than anything.. particularly if it's a later roller motor.
Old Sep 27, 2009 | 10:54 AM
TigerDan's Avatar
TigerDan
If the tag is missing and it's never been rebuilt with the deck resurfaced, you can at least get the engine assembly date from the small pad at the front of the driver's side of the block, right at the base of the cylinder head:
When these engines were assembled the date code was stamped into this pad. If the deck has been surfaced then the stamping would be removed as this pad is an extension of the deck. Clean it off and look carefully...
taneum
19
Jan 8, 2023 01:15 PM
woodlander
Nov 7, 2014 04:06 PM
wooddyusa
17
Aug 28, 2013 12:42 PM
nataneely
Dec 14, 2008 10:50 AM
