Help noob with fuel problems
Old Sep 26, 2009 | 08:04 PM
87_gt's Avatar
87_gt
Hi all
I was hoping to get some help on this new issue. i have a 1995 ford F250 with the 5.8l in it. a little background on the issue. last week i had a new side mount fuel tank installed. once i got the truck back the fuel guage was acting up, it was pegging all the way out and then would go back down. just very unpredictable needle movement. i figured that a wire had just gotten exposed getting a bad signal. i gave the truck an oil change this morning and then when i went to go and drive it about 3 hrs. later, it died out on me about a block down the road. it will start and idle fine, it just dies out when i get into the throttle. It runs fine on the rear tank. Is this a fuel pump problem? did the fuel pump go out, or is there a possibility that a wire is just not getting good signal (similar to the guage problem). since the truck is a chicago truck there is a rust problem, so could it just have a bad ground? i really have no clue as to how the wiring on these goes so i am really at a loss at where to start. any input at where to start looking would be great. i am leaving to drive the truck from florida to chicago on tuesday so i would love to get this fixed soon.
Steve
Old Sep 26, 2009 | 08:14 PM
subford's Avatar
subford
Sounds like a pinched fuel line from the front tank to the frame.
Old Sep 26, 2009 | 09:47 PM
87_gt's Avatar
87_gt
this is the second time i have put fuel in it. when i first got the truck back a week ago i put like 5 gallons in it, and ran that low. i then filled it about half way 2 days ago and it ran fine up until a little bit ago.
Old Sep 26, 2009 | 11:11 PM
ottawaguy's Avatar
ottawaguy
Certainly sounds like they did something when they installed the new tank.
I would go back to the shop that did it and explain what's going on.
Hopefully, it's a quick fix and they will make it right.
Old Sep 26, 2009 | 11:21 PM
tseekins's Avatar
tseekins
Veteran: Coast Guard
Did they replace the OE tank with an exact duplicate? My '88 had a grounding issue. I replaced the ground wire and the all four wires that form the harness to the pump connector.
I would definately investigate what Subford said as well.
Tim
