Dually Tire Question
Old Sep 26, 2009 | 12:52 PM
DieselE's Avatar
DieselE
What is the biggest tire i can run in the rear of a dually without the tires rubbing, stock is a 235/85r16, would like to put 285/75r16's on but those tires have a one inch wider section with than the stock size tire, i'm not sure if they would rub, is there a spacer that can be placed in between the rims to avoid the tires rubbing.
Old Sep 26, 2009 | 02:01 PM
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
i believe that the 255's are the widest you should go so that when you put a load in the back and the tires swell a little there is still clearance between the two......
Old Sep 26, 2009 | 07:57 PM
DieselE's Avatar
DieselE
thanks, its my brothers truck, i have all single rear units, but thanks for the info, he was wanting to put the 285's, does anyone make a spacer?
Old Sep 26, 2009 | 09:08 PM
clintbonnie's Avatar
clintbonnie
With those big tires, I would suspect your brother might have trouble with traction in the snow.. The back of the truck will ride on top of the snow instead of pressing into it.. just IMO...
Old Sep 26, 2009 | 10:33 PM
whitesdford's Avatar
whitesdford
I had 265/75/16s on my dually with factory wheels. Went with new aluminum wheels, and guess what, the offset of the new wheels is an inch shorter, so I had to go with 235/85/16s.
The 265s I had on stock wheels were geolanders and they fit fine, even with a load on.
Old Sep 27, 2009 | 09:54 AM
Blacked-Out's Avatar
Blacked-Out
They make spacers to put between the tires. My dad is running pro comp AT that are 35" high and 12.5" wide. There is a 2" spacer in between.
cblade1993
27
Jan 6, 2015 09:27 AM
a2dudley
Aug 29, 2011 06:52 PM
036.0stroke
Jan 29, 2011 03:34 PM
The Grinch
Nov 24, 2009 06:31 PM
carlsson
Apr 27, 2008 05:55 PM
