Sponsored by: Auxito
Slow Idle
Old Sep 26, 2009 | 12:07 PM
SteevenH's Avatar
SteevenH
Slow Idle
I have a 99 F250 LD. 5.4l . When I first start the engine it won't idle up past 500 rpm. After the engine warms it will start and Idle fine. Any suggestions? TPS? Timing? PCM? Also , what is the best code retriever for the money , for this vehicle?
Old Oct 2, 2009 | 07:50 PM
ccomper's Avatar
ccomper
I recently had a problem with my truck starting, then stall immediately. It would then stay running after cranking for 5 seconds or so on the second attempt. Idle speed was low until engine warmed. I pulled the AIC (Idle Air Control) valve and bench tested with 12V. The solenoid just clicked, but didn't move the valve. I picked up a new one at NAPA for $62 and installed. Solved the problem immediately and has been running fine since.
Old Oct 3, 2009 | 08:15 AM
l-m tech's Avatar
l-m tech
i second the iac.also check for the vacume leak at the pcv elbow.
