Running lights going out
Old Sep 26, 2009 | 09:15 AM
Whiskey Bent's Avatar
Whiskey Bent
Got a '78 f-350 that I pull a 30' trailer with. When I have the trailer hooked my running lights will turn off for a few seconeds then come back on for about a minite. They dont do this with out the trailer and it takes 10 minutis before it happens then does it all the time. Headlight stay on just running lights. Something is clicking under dash when they go out? Is there a relay? Please help!
Old Sep 26, 2009 | 01:04 PM
mlcopen69's Avatar
mlcopen69
maybe your headlight switch is going bad??? i had this problem but with no trailer hooked to it try your headlight switch
Old Sep 26, 2009 | 02:54 PM
Whiskey Bent
Thanks! I will try it.
Old Sep 26, 2009 | 03:14 PM
mlcopen69's Avatar
mlcopen69
or your trailer could be wired wrong causing a short in the lights maybe hook up to a friends trailer and see if it still does it
Old Sep 28, 2009 | 04:17 PM
Whiskey Bent
Thanks again for help, I found a bare wire on trailer that would bounce and hit it.
Old Sep 28, 2009 | 04:19 PM
Bdox's Avatar
Bdox
Surprising that didn't cause it to blow a fuse!
