engine turns but doesn't start
Old Sep 26, 2009 | 01:03 AM
derrickm's Avatar
derrickm
So the interior dome light was left on in my 1984 302 F-150 and the battery died. I pulled the wife's car over to jump start the old Ford and in a moment of retardation I reversed the "+" and "-" jumper cables between the two vehicles. The wife's vehicle is just fine, mine didn't do to well.
Smoke came from the general area of the starter relay and after a little looking around I found the reminants of a 16ga fusible link that had vanished. I went to my garage and grabbed a short section of 12ga romex and stuck it into the air space that is suppose to be protected with the fusible link. I re-jumped the truck and it started right up. Then I had my second moment of retardation. With the truck running I reached under the hood and removed my 12ga splice. The truck immediately stopped and I haven't been able to get it started since.
I've replaced the fusible link. I've put in a new battery and a new coil. The engine turns over just fine but I can't get a spark out of the coil. All of the fuses under the dash are good. Is there some other section of fusible link somewhere that I fried? Could I have fried my ignition module?
Old Sep 26, 2009 | 08:24 AM
ctubutis's Avatar
ctubutis
I understand there are two or three of those links in the same general area....
Old Sep 26, 2009 | 01:26 PM
Opossum's Avatar
Opossum
Start by seeing if there's any power to the positive side of the coil. Check both in run and crank.
Old Sep 28, 2009 | 12:04 AM
derrickm's Avatar
derrickm
Thanks for the input. I had power on the positive side of the coil but couldn't get anything to out on the negative side. I took a chance and swapped out the ignition module and got lucky. The old beast is back to starting everytime.
HighOctane23
Jan 30, 2021 02:19 PM
sjbrink
59
May 20, 2016 02:54 PM
Island Time
Electrical Systems/Wiring
Jul 6, 2014 07:26 PM
fifties_forever
Oct 30, 2009 02:30 AM
mramelbass
Jul 21, 2004 07:17 PM
