Help With Codes
Old Sep 26, 2009 | 12:58 AM
throwdown's Avatar
throwdown
Help With Codes
I can't find these codes on the posted list. Can anyone tell me what they are?
P1670 and P0541. And of course the standard P0603.
I'm sure one of them has to do with the AIH delete, but I don't know which one.
Thanks
Old Sep 26, 2009 | 02:03 AM
throwdown's Avatar
throwdown
OK, I have found so much conflicting info on the P1670 that I don't know where to start.
I know that I need to replace both batteries, ( she's an '01 with the original bats ). I will get them changed and then clear codes and see if it returns. I am pulling the turbo soon for up pipe install and WW install, so I can check the UVCH and do the .50 mod. That may also be the problem. I will also replace the IDM relay.
Any other ideas?
Old Sep 26, 2009 | 07:12 AM
rat49f6's Avatar
rat49f6
P0541 - is from aih delete
p1670- from what i rad in other threads ur pcm and idm arent communicating
use the search function and type in p1670 you will find tons of reading
Old Sep 26, 2009 | 08:24 AM
kerrys99f350's Avatar
kerrys99f350
Uhh,,,just did 1670 on my 99 f350. Was 3rd relay in box under the hood. Also could be fuse right beside it, next row. Mine would'nt start with out it. Good luck....
Old Sep 26, 2009 | 04:35 PM
throwdown's Avatar
throwdown
Thanks for the info guys. Will test relays most ricky tik.
