no turbo boost
Old Sep 25, 2009 | 09:38 PM
birdnestfarm's Avatar
birdnestfarm
no turbo boost
I have an 88 f-350 with a 7.3L with only 59,000 miles. It has a Banks turbo with no boost psi and very little power. Replaced O-rings on injectors today to stop fuel leaks, has no exhaust leaks, turbo spins. This is my first Diesel and my 5.4 triton in my expedition can run circles around it. Anyone know what the problem is?
Old Sep 25, 2009 | 09:42 PM
Dave Sponaugle's Avatar
Dave Sponaugle
birdnestfarm,
Welcome to FTE and the IDI diesel forum.
First thought is the air cleaner condition, recently changed?
Are you seeing any black smoke when you floor it going up a hill?
Do you have a boost gauge or are you going by sound?
Old Sep 25, 2009 | 09:52 PM
birdnestfarm
recharged K&N filter, no black smoke, while hauling a tractor today boost gauge went to 3psi but speed dropped to 15mph
Old Sep 26, 2009 | 10:06 AM
axe_handle's Avatar
axe_handle
Do you have a pyrometer? If so, what are your EGTs? No power, no boost, and no black smoke makes me wonder if it is getting enough fuel.
Old Sep 26, 2009 | 12:46 PM
birdnestfarm
not sure, i have an exhaust temp. gauge, oil temp, and boost, how do I check the fuel flow?
Old Sep 26, 2009 | 01:09 PM
axe_handle's Avatar
axe_handle
Your exhaust temp gauge (exhaust gas temperature , or EGT) is a pyrometer. It would be good to know where the temperature probe is placed on your truck (before or after the turbo). What is your exhaust temp gauge reading when you are making 3 PSI of boost?
Old Sep 26, 2009 | 10:26 PM
Dave Sponaugle
Sounds like the fuel setting is to low.
Old Sep 26, 2009 | 10:54 PM
joe f350's Avatar
joe f350
i would have to say fuel to low and to much air
Old Sep 26, 2009 | 10:58 PM
Dave Sponaugle
No such thing as to much air for a diesel.
Old Sep 26, 2009 | 11:00 PM
joe f350's Avatar
joe f350
realy i though it had to be very percie ratio for best power
Old Sep 27, 2009 | 05:45 AM
mistakenID's Avatar
mistakenID
With only 3 psi, loaded and pulling there either has to be an air restriction or something is keeping the impeller from winding up. That is assuming that you have no intake or exhaust leaks anywhere.
I would think that even if the fuel had not been turned up, that under a load and pulling, the turbo would be capable of boosting more that 3 psi.
Maybe the IP is going junk. Low mileage but still it's over 20 years old. The plastic coupler (internal in the injection pump) could be coming apart and restricting fuel.
How about the muffler? Is it OEM or does it have the Banks 3" that could be ordered with the turbo? If it's the original muffler it could be plugged up (again age related and falling apart inside)
Old Sep 27, 2009 | 02:40 PM
Dave Sponaugle
Since there is no throttle body on a diesel, it takes in a full charge of air on every intake stroke.
The only thing that can cause less air to enter the cylinder is either a clogged filter or some other restriction in the intake.
The amount of fuel injected is all that causes the engine to speed up or slow down.
So every time you are slowing down, the engine is running "lean" to use a gasser term.
When you are accelerating, the engine is running "rich" when it starts to give off any black smoke.
Part of the reason a diesel can get better fuel mileage is the fact there is no optimum fuel air mixture that is maintained constantly like it is in a gas engine.
When you are slowing down as long as the engine speed is higher than the govenor is asking for, there is no fuel injected.
With no leaks in either the turbo boost side or the exhaust manifolds to turbo connections, there is only a couple things left that can result in low boost.
Restrictions in the air intake, restrictions in the exhaust after the turbo, or not enough fuel going to the engine making heat to drive the turbo.
Old Sep 27, 2009 | 03:03 PM
tjc transport's Avatar
tjc transport
i ain't rite
a banks turbo system mounts the pyro probe in the turbo pedestal, just before the turbo.
also, a banks non waste gated turbocharged 7.3 idi with a muffler on it will only produce 3-5 lbs boost.
if you take the muffler off, you should see around 10 lbs boost at full throttle with an auto trans, and around 13 lbs with a manual trans.
Old Sep 28, 2009 | 06:00 PM
birdnestfarm
there is no intake restrictions, truck has 3" muffler not sure if its restricted, never blows black smoke, so how do I turn the fuel up?
Old May 31, 2011 | 10:14 PM
birdnestfarm
took out muffler so how do i turn up the fuel?
