Anyone know what numbers I need to match to get a different IDM for my 95? The guy in Florida is out of stock and I found another one but dont know what numbers I need to match. I have a F5tf-128599=ab. Thanks
I still cannot figure out which box it is on my fender.
were they in a different place in 94?
I doubt it.
You can't find a silver box mounted on the driver's fender just below the hood hinge? Rectangular wire harness/plug screws into it from the front, box has 3 bolts holding it to the fenter, 2 on top one down low toward the firewall.
BINGO!
Hints:
1) The plug is screwed in with a 10mm (I think, maybe 8??) bolt. You back that all the way and it pulls the plug away from the IDM, but it also has a clip that you have to pry away to get it all the way off.
2) You don't aave to remove the lower bolt, just loosen it up. The Box is notched and it slides past the bolt. Helps so you don't have to hold it up while taking it in and out.
BINGO!
Hints:
I have read some write ups and I dont remember that tip (number2).and let me tell you that at the begining I thought that thouse 3 bolts was only for the cover of the IDM and I was trying to find the bolts that attach the IDM to the fender
I love this forum. I learned something today. Reps sent.
