Swapping 97 engine into 01.
Old Sep 25, 2009 | 04:54 PM
Quick444's Avatar
Quick444
I have a long thread going on about this in the 99-03 section but at this point in my swap I have a specific question.
I was told that there is a plug in the valley of the engine that I will need to plug up when I remove the mechanical fuel pump. In my case, when the fuel bowl and pump were being pulled out the pump section somehow broke off. Basically, I can see a hole in the bottom of the valley but its perfectly plugged up. Do I need to worry about this if I am swapping into an 01?
Thanks
Old Sep 25, 2009 | 07:01 PM
250turbo's Avatar
250turbo
Alex,roll engine over.tappet and bottom of fuel pump should push up. tappet rides on cam.good luck.
Old Sep 25, 2009 | 09:18 PM
MustangMatt96GT's Avatar
MustangMatt96GT
Use a 7/8 freeze plug... thats what I have seen used on the OBS trucks when going to electric fuel...
Old Sep 26, 2009 | 10:04 AM
WALJON's Avatar
WALJON
Make sure the tappet from the old pump is still visible hopefully it didn,t fall in the block !
Old Sep 26, 2009 | 09:20 PM
oldbird1965's Avatar
oldbird1965
I read if it does fall, it will end up in the oil pan. But, slowly turn the motor over so it can fall before starting the motor.
Old Sep 28, 2009 | 07:28 PM
Quick444's Avatar
Quick444
It broke evenly in half. A smaller object in the middle of another form of metal. I RTVed that section and after turning the engine over twice by wrench, I was unable to see anything buldge the RTV sealant. What is my next step? I still have the engine out.
Old Sep 28, 2009 | 08:08 PM
WALJON's Avatar
WALJON
Well If what you are saying is the pump broke in half and the part of the pump that goes in the block is still in there chances are the tappet is in the motor and it will make it,s way to the oil pan by turning over by hand like stated above but seeing how you have the engine out you may want to take the oil pan off and see if it is in there I know I would.
Old Sep 28, 2009 | 08:13 PM
Quick444's Avatar
Quick444
I will pull the rtv sealant and see if I can see it. If there is a hole then I will pull the pan.
Old Sep 28, 2009 | 09:20 PM
Gobstopper909's Avatar
Gobstopper909
quick, if you could get some pics, that would be great.
Old Sep 29, 2009 | 12:25 AM
Quick444's Avatar
Quick444
Managed to figure it out. Pulled the tappet and rod out. Then covered it up with a dead sensor and rtved it up.
James Shook
Jun 6, 2014 09:32 PM
woodtrucker
Mar 4, 2014 07:00 PM
bk117wrench
Aug 10, 2013 10:52 PM
fridgeddiesel
36
Jan 3, 2009 08:40 PM
MPlayer
20
Oct 26, 2005 04:14 PM
