DOT 5 Brake Fluid???
Old Sep 24, 2009 | 07:33 PM
Supercab's Avatar
Supercab
Wink DOT 5 Brake Fluid???
Just wondering if anyone is running it and their opinions?? My 1965 Mustang was recently restored and they put the stuff in and I understand it absolutely will not harm paint, has a very high boiling point, is silicone based (not synthetic) and heres the kicker...it WILL NOT absorb moisture so evedentally it will allow moisture to form and just sit in the system and possibly rust out the metal parts from the inside out.....
I am running DOT 4 synthetic in my '99 F350 Dually and have great brakes, btw.....
Old Sep 24, 2009 | 08:30 PM
SpringerPop's Avatar
SpringerPop
ALL DOT3/4 is technically "synthetic", so the manufacturers touting it aren't saying something "special" about their products.
Silicone brake fluids (DOT-5) have a tendency to entrain air bubbles (or worse, foam) in systems with a separate ABS pump, causing a soft pedal.
The best applications for DOT-5 fluid that I've found are those older cars without ABS.
Just like your Mustang....
Pop
Old Sep 24, 2009 | 09:10 PM
Highboosted's Avatar
Highboosted
DOT 5 fluids do not have a higher boiling point than most performance DOT4 fluids, and unless you seriously neglect your brake system you will not ever see the wet boiling point of a good DOT 4 fluid. A couple of the classes I race in specifically do not allow DOT 5 fluid because it's practically impossible to bleed all the air out, but in a street car you'll never see anywhere near boiling point unless your seriously doing something stupid. I personally use Motul RBF 600, most of my buddies use it or ATE type200/superblue or Castrol SRF.
Anyways, if the system was redone and they used DOT 5, your pretty much stuck with it without a bit of work to properly clean the system out. The two fluilds do not play well together. Your fine with what you have in that application. BTW, there's more chance of corrosion with DOT 5 than DOT 4, because the moisture isn't absorbed.
WA.Ranger's Avatar
WA.Ranger
You DO NOT want to mix DOT5 with DOT3. IIRC They will eat seals up. (Thanks Crown Fork Trucks!)
Old Sep 24, 2009 | 09:14 PM
SpringerPop
Can you provide something to expand on this?
Thanks,
Pop
Old Sep 24, 2009 | 10:48 PM
WA.Ranger's Avatar
WA.Ranger
It's what I learned as a mechanic for DC powered forklifts many moons ago. I have seen master cylinder seals swell and then fail when people that didn't know mix the two. It was on a deadman brake system thank goodness. I did a quick search and came up with this article. I guess there are 2 kinds of DOT5, I was referencing the silicone based version.
http://www.gabma.us/docs/dot5.pdf
I realize that this could be some Joeblow, but it's something I guess we could write an email to DOW or such if we really wanted hard facts. If I'm wrong, than forgive me, I've been mislead.
Old Sep 24, 2009 | 11:06 PM
PwerStroke99's Avatar
PwerStroke99
Ranger is correct. u do not want to mix the two brake fluids. It has been done by mistake many times in the military, and if caught soon enuf, u can save it from damage. I have seen it happen a few time sin the Military. The HMMWVs take the DOT 5 where as everything else takes DOT 3
Old Sep 25, 2009 | 12:29 AM
SpringerPop
I know you can't successfully mix the two types. They are completely different, incompatible chemistrys.
I was attempting to get some documentation of seals failing as a result of converting to DOT-5.
That's why I quoted, "They will eat seals up" and asked for more info.
Is there some kind of reaction when the two types are brought into contact? That's something I've never heard of.
At least not yet....
Pop
Old Sep 25, 2009 | 05:38 AM
Supercab's Avatar
Supercab
Wink
Guys, I totally forgot about the fact that you are not to use DOT5 in ABS equipped systems before I asked the question-sorry.
I can't see any real benefit of the 5 in my Mustang since its hard to bleed-my pedal is soft and spongy since the restoration-I don't think they worked with it enough to get all the air out of it.
I think the main reason for its use around antique/classic cars is the non-paint damaging properties.......I'm seriously thinking of flushing the system with alcohol as my Mustang buddies suggest and put in a good quality DOT4.
Old Sep 25, 2009 | 09:38 AM
Highboosted
That would be my suggestion. I personally would recommend ATE type 200.
3twinridges
Jul 25, 2017 10:45 AM
mhatlen
Jul 12, 2012 02:37 AM
Jermafenser
Oil & Lubrication
20
Mar 21, 2010 08:42 PM
bbass408
1983 - 2012 Ranger & B-Series
Jun 26, 2009 09:27 PM
orleec
Oct 28, 2005 09:46 AM
