is there any way to make the fog light stay on with high beams? and is there any way to make them come on with the parking lights with out adding a switch would like to keep factory switch?
Are you sure the BriteBox does the fog lights as well as the low beams? If I built it, it would. BUT, I don't have one so I don't really know for sure.
sounds like a good idea just need to know what color and a little more detail please.
Originally Posted by WA.Ranger
Jim, do you know if that will work on Canadian trucks?
I will have to take a look at the diagram. As soon as I unpack the box that the disc is in. Moving s***s.
I think that it would Jeff. The only difference is the DRL. IIRC
If you want to see exactly what the BB does for you pull back on the dimmer switch using the "flash to pass" feature. This is the EXACT same thing a BB does, but without having to hold the arm back.
I see...with FLC it will operate the fog lights!
IIRC there was a purple wire and a black w/ white tracer, but I really don't remember anymore. Have you found anything when you searched? Like I said, it is hard to find. I had it bookmarked on my old computer.
