dc power plug
Old Feb 13, 2002 | 08:29 AM
okaufman's Avatar
okaufman
dc power plug
ok i have a dc power recpetacle in the front of my expedition and also one in the back. The one in front works just fine, but the rear one does NOT work. Are they on seperate fuses? is there a trick to making the rear one work? I can live without it but it would be nice to have both working
p.s its a 2000 eddie-b expedition
Old Feb 13, 2002 | 08:49 PM
Petrol's Avatar
Petrol
dc power plug
I am not sure of what you ask.
Are you refering to the power points that look like cigar lighter recepticals?
One on the dash next to the cigar ligher and the other on the rear of the center console?
Check the fuse box, they are labeled pretty clearliy and if "burnt" easy to spot. I think this is most likily your problem
Old Feb 14, 2002 | 09:16 AM
Drawsoncad420's Avatar
Drawsoncad420
dc power plug
Im not sure if the center console is the same in the 00' as in my 01' Xped, but it is pretty easy to get to the wiring to the rear Power Plug. Maybe the connector came loose or something. Im gonna try and do this from memory, I wired neon in on my subs off of that power outlet. You have to open the center console, unscrew the (4) Phillips heads that hold the lid of the Center Console on. Remove the (2) Torx that are behind the bracket once you get the Lid off. Open up the cup holders in the back, just above the power outlet. You will see (4) screws towards the back of the assembly(not sure whether they are torx of phillips). After that, the whole panel, which consists of the Radio/AC faceplate, and the back of the center console housing should pop right off. Everything you need is right there. Thats the easiest way i can think of finding your problem. One thing i do know is, i dont think Ford wanted anyone taking that damn center console apart, I had the whole thing in pieces when i was running auxilliary wires to the switches up in front of the cupholders, and i ended up with like 20 some bolts between torx, philips, and some socketed bolds at the base of the unit. Well hope this helps. I dont think ill be opening it up again soon, but if i do...i get some pictures up here for you, to somewhat help you with the process. Good luck, hope it all works out...
Old Oct 6, 2002 | 12:40 PM
THEMASKEDRIDER's Avatar
THEMASKEDRIDER
dc power plug
Old Nov 2, 2002 | 01:53 PM
peteacpo's Avatar
peteacpo
dc power plug
>both working
On my 98 expedition the fuse for the console power socket is located in the engine compartment in the fuse panel. I had a blown 25amp fuse on mine.
kschroeder.DVM
Vehicles for Sale
Jan 26, 2017 09:33 AM
Seven11
Feb 9, 2016 02:25 PM
richsoucie
Apr 6, 2015 03:51 PM
1997 Expedition EB
Oct 28, 2010 06:20 PM
DASP
Dec 21, 2006 10:53 PM
