altertenator
Old Sep 23, 2009 | 03:41 PM
bartric's Avatar
bartric
altertenator
Yes I have a 2004 f-250 6.0
I think I need to replace my altenator but I am getting confused on duel altenator singel . when I volt test it on the alentenator Io was getting 13.9 volts on ideal i cant read the amps, and I just replaced the passenger battery last week I know I am supost to change both at the same time but money is short, now my battery light comes on every once in a wile both batterys are at 12.5 volts when I shut the truck off any help would be nice
Old Sep 23, 2009 | 03:52 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
You should have both batteries tested - make sure they test them with the OTHER battery disconnected. You will prob find that BOTH batteries were bad.... I know $ is tight, but we are tossing $ out the window by only replacing one!
Old Sep 23, 2009 | 07:56 PM
liv's Avatar
liv
+1 on bud
Get cheap batteries if you have to. Its going to save your rather than having to replace the alternator again.
Replace both of them and then test your alternator to see if you need to replace. You might look in to a dual alternator set up with all that audio equipment you're running, but if moneys tight that wouldn't be real high on my list. Just get a high amp one. You can rebuild your current alternator to save some cash. Just look for a shop in your area.
Old Sep 23, 2009 | 08:17 PM
bartric's Avatar
bartric
Okay stopted at O'Reilys had them check batterys said they where good had them check the alternator it was 13.5 volts and 46 amps he said it was good but a little week so I replace the second battery, while taken it out I realized it as a 750 cranking amp battery and the one he sold me last week was 650 so I ask him I want a 750 and he said sure So they took back the one from last week and I got 2 new batterys I hope this works and the light that only came on a few times last week goes away.
Old Sep 23, 2009 | 08:29 PM
liv's Avatar
liv
If the battery light is still coming on even with new batteries you have a charging problem.
Old Sep 24, 2009 | 12:30 AM
ford7379trucks's Avatar
ford7379trucks
the light reads the voltage only. so you get 13.9v when running and 12.5v when not running. That is what they are supposed to be. dose the light only come on when its not running. If so dont worry about it. The light is for when its running.
Old Sep 24, 2009 | 08:34 PM
bartric's Avatar
bartric
Light still came on today on and off now I found a part that I dont know what it is and it is cycling on and off like a fish airator its behind the passerger battery on the fender well when the truck is runnng and when the key is turned on it will come on for a few seconds and then off and then back on, I am so confussed.
