Overheating Mystery
Old Sep 23, 2009 | 01:16 PM
MXRACER428's Avatar
MXRACER428
Cool Overheating Mystery
I have an 04 F-150 4x4 5.4 Liter with 6" Lift, Flowmaster Dual Exhaust, Volant cold air intake, and the EDGE Tuner Chip with 80,000 miles and I have been having trouble with my truck saying it is overheating but if I pull over turn the key off and turn it right back on than the gauge goes right back to the middle and says it is fine! It only does it at highway speed and going up hills. It did it before I ever put all the extras on the truck also, but it used to not do it very often at all like maybe 5 times a year. now it does it every time I go up an incline at Highway speed I have replaced the Temp Sending unit any other ideas? Thanks for any help!
Old Sep 23, 2009 | 01:32 PM
69 f-100 aman's Avatar
69 f-100 aman
CK. fan clutch and thermostat,sounds like fan clutch to me
Old Sep 23, 2009 | 01:33 PM
silver05fx4's Avatar
silver05fx4
i would try a new thermostat first its only a couple of bucks
also if you have a edge set so you can look at the coolant temp to see if it stays arould 210 degs
Old Sep 24, 2009 | 09:56 AM
MXRACER428's Avatar
MXRACER428
I already have my edge set to show the coolant temperature. It goes above 210 and my gauge on my truck goes to all the way hot but it doesn't rise slowly the gauge goes from in the middle straight over to the hottest side in like half a sec! I don't think it is the thermostat because the truck magically "cools off" in the amount of time it takes me to turn my truck off and turn the key right back on than the temp is back to normal so it is like saying it is overheating but I don't think that it is actually overheating?
Old Sep 24, 2009 | 10:08 AM
FTE Trigger's Avatar
FTE Trigger
Can you "Spin" the fan by hand? Does it have a wobble or shake if you do handle it?
Old Sep 24, 2009 | 10:18 AM
MXRACER428's Avatar
MXRACER428
Yes I can turn it by hand and it is tight no wobble or shake
Old Sep 24, 2009 | 11:17 AM
silver05fx4
so pretty much what your saying its the gauge will peg hot
so you shut the truck off and start it right back up and its fine, gauge back to the right spot and the truck never does over heat but the gauge goes crazy
Old Sep 24, 2009 | 11:31 AM
MXRACER428's Avatar
MXRACER428
yeah pretty much because I never have any coolant boil out and when I turn the key back on instantly it is not hot anymore. I heard it might be a short in one of the coils would that be possible? it says on both the factory gauge and the EDGE gauge that its hot but bothh go back to normal after I turn the key off than back on
Old Sep 24, 2009 | 12:05 PM
shorebird's Avatar
shorebird
Originally Posted by MXRACER428
it says on both the factory gauge and the EDGE gauge that its hot but both go back to normal after I turn the key off than back on
I suspect the temp sensor is faulty. It is providing the info to both the Edge and the gauge.
Old Sep 24, 2009 | 01:03 PM
silver05fx4
he said he replaced it already
did you replace the one in the head?
Old Sep 24, 2009 | 03:23 PM
MXRACER428's Avatar
MXRACER428
Yeah I did it cost me over $500 to get it installed! I was really mad when that did not fix the problem at all. Since a mechanic told me it could be a coil shorting out I was thinking of getting all new coils would that be a good idea at all? I have replaced all the spark plugs already like 20,000 miles ago and I just replaced the thermostat
Old Sep 24, 2009 | 03:37 PM
silver05fx4
what!!! the parts less than 50 bucks
i don't see how it would be a plug or coil issue
Old Sep 24, 2009 | 03:54 PM
MXRACER428's Avatar
MXRACER428
yeah i know the part wasnt much it was all the labor to put it in because it is so far down in there. It is really frustrating because I can't go anywhere out of town on the highway at all. I tried to drive it like 45 min down the highway and I had to pull over like 4 times because it said it kept overheating yet nothing boils out or anything
Old Sep 27, 2009 | 11:49 PM
shorebird's Avatar
shorebird
Maybe you can install a temporary gauge to see if it really is overheating. http://www.amazon.com/Auto-Meter-233.../dp/B00062YVSO
BUT I really believe that you have an electrical problem with the sensor.
Old Sep 28, 2009 | 04:00 AM
FTE Trigger
I wonder if the tech rung the wires out that service the temp sensor?
rscd
Dec 4, 2010 06:22 PM
PowerHound
46
Jul 13, 2010 11:08 PM
broncoman72
1997 - 2003 F150
Jun 22, 2010 01:09 PM
Turbo_Bimmer
Jan 13, 2008 03:58 PM
sa_rains
19
Jun 4, 2006 10:02 PM
