str8 6 question
Old Sep 22, 2009 | 09:23 PM
8525ford's Avatar
8525ford
str8 6 question
i bought a used 89 4.9 motor and it was fuel inj. its goin in my 85 carb truck. problem is that on the side of the block where the mechanical fuel pump is supposed to go is sealed off because it was fuel inj. Is this no good or can i put a inline electric fuel pump in?? i just realized this when i was tearing it down.
Old Sep 22, 2009 | 09:31 PM
Blu-Pixie's Avatar
Blu-Pixie
Pretty sure you can run an electric pump - don't forget a good regulator!
Can the 85 dist. swap into the newer motor?
Old Sep 22, 2009 | 09:40 PM
greyghost85's Avatar
greyghost85
probably even pick up a couple more HP.
Old Sep 23, 2009 | 01:36 AM
Kuskoal's Avatar
Kuskoal
I heard in the inline forum that you can drill it out to make a mechanical bolt in, not sure if the fuel pump eccentric is there though.
Old Sep 23, 2009 | 07:30 AM
stanggt84's Avatar
stanggt84
Electric should work, just make sure that it is a low pressure pump and that you install a regulator of some kind. A carburetor will get overloaded if it is being supplied fuel at a pressure that is higher than the 5-9psi that it was designed to handle.
Old Sep 23, 2009 | 01:18 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Yes.
The block can also be drilled out for a mechanical pump as described by Kuskoal as well. I am not sure of the pump eccentric either.
The Inline Six forum would be able to help if you go the drilling route.
They also make a Pump block off plate for going the other way.
