Axles-???
Old Sep 22, 2009 | 12:50 PM
rockher_man's Avatar
rockher_man
Lightbulb Axles-???
...uhh...
Will the stock axles out of an 28-spline 8" rear end will swap into a
28-spline 9" rear end???
As long as everything else is the same...bearing size, length......
Old Sep 22, 2009 | 01:41 PM
85e150's Avatar
85e150
Maybe.
http://www.currieenterprises.com/ces...e.aspx?id=1041
They show the same part number for both 8 and 9 for standard 28 spline axles.
As you note, length of the axles and bearing sizes might be issues.
Numberdummy can probably see if there is a Ford part number match.
Old Sep 22, 2009 | 03:47 PM
RTM's Avatar
RTM
Depending on bearing size and axle width, yes they will swap between each other. I know on the early mustangs they did.
Old Sep 24, 2009 | 10:10 AM
rockher_man
Thumbs up Kool...
Thanks...
