Multiple Questions
Old Sep 21, 2009 | 06:41 PM
94XLT5.0's Avatar
94XLT5.0
Multiple Questions
OK here goes-first off my OD light blinks off and on, it does it and then stops, it seems like when its blinking my truck is surging. Everything is downshifting and upshifting as good as what a 15yr old truck is expected to do. Seems like maybe when the TC locks up I hear vibration, but it sounds like its in the rearend. Also when the OD light is blinking my cruise doesn't work.
When I am going down the interstate and I am going 75-80mph lots of people are passing me. I got passed by a Ford ranger the other day on the highway and I was going "65 mph". Anotherwords I think maybe my speedo is off by a hair.
Horn doesn't work and air bag light blinks 2 then 3 times, these are definitly on the bottom of my list though
thanks for the help in advance.
Old Sep 21, 2009 | 06:43 PM
Volvo92906's Avatar
Volvo92906
guarantee someone is going to say check the fuses. So, do it.
Old Sep 21, 2009 | 06:49 PM
94XLT5.0's Avatar
94XLT5.0
I did check the fuse for the horn, I kinda figure its a relay, knew I should've added that. lol
Old Sep 21, 2009 | 07:08 PM
ryanfrompoco's Avatar
ryanfrompoco
as for the speedo is you truck running stock size tires or 33" or 35"?
do you have a diffrent gear ratio or is it stock ?
Old Sep 21, 2009 | 07:37 PM
danr1's Avatar
danr1
Check for trouble codes, the flashing OD light is a pretty good indicator it will or at least should have one and maybe more saved in CM.
Old Sep 21, 2009 | 08:13 PM
94XLT5.0's Avatar
94XLT5.0
I ran the codes the other day and all I had was a TPS code and I replaced the TPS and no more CEL. I will run the codes again 2mrw, I have stock tires and stock gears. The only thing aftermarket on the truck is a K&N filter and a Flowmaster.
Old Sep 21, 2009 | 09:24 PM
bazzman1953's Avatar
bazzman1953
Get rid of the K&N airfilter, if they were so great Ford would be installing them as OEM. I will never install one of them on ANYTHING that I drive. Go back to stock.
Just my 2 cents.
Old Sep 22, 2009 | 07:28 AM
94XLT5.0's Avatar
94XLT5.0
Never had a problem out of them in my life. The OD light blinking is my big problem.
Old Sep 22, 2009 | 12:44 PM
Elderstarr's Avatar
Elderstarr
Horn does not work, along with cruise control, plus the airbag light is blinking?
Sounds like the clockspring to me.
Quoted by TEGIII
quick check..unplug the clock spring under the dash where it goes up into the air bag.. put a 1ohm resistor inplace of the clock spring..if the light is out then the clock spring is bad...common problem.
You will have to remove the steering wheel to get to it. $90-$100.
Old Sep 22, 2009 | 03:32 PM
94XLT5.0's Avatar
94XLT5.0
The only time the cruise control doesn't work is when the OD light is blinking. I drove the truck all day 2day and it didn't blink one time. Its pretty random
Old Sep 22, 2009 | 03:36 PM
skaterbro's Avatar
skaterbro
Pull the VSS and clean any metal shavings off it and re-install. See if that doesn't remedy the flashing OD light and cruise problem.
Old Sep 22, 2009 | 03:38 PM
alxsnmr's Avatar
alxsnmr
Do the clock spring test. The clock spring is related to all the controls on the column: horn, airbag, signals, etc.
It sounds like you have multiple problems though rather than one solution. It is going to take you a bit to work them all out. Are you the orginal owner of this truck? I ask because if you are not, someone may have recalibrated your VSS for larger tires so you may need a recalibration of your vss again to get the speed right. But do as skaterbro suggests as the VSS is known to cause shifting problems, speed problems, and other assorted things as it begins to go bad.
In my experience K&Ns and MAF do not mix well, I speculate that the oil that gets pulled off the filter onto the MAF causes problems and sometimes a failure of the MAF. K&Ns on Carbs and SD systems are not a problem. Turbos/superchargers I have no opinion on. Though not having to buy a new filter every year does have its benefits.
Old Sep 22, 2009 | 07:53 PM
94XLT5.0's Avatar
94XLT5.0
It seems like my speedo is only off when the OD light is blinking, but then again I have been driving cars for years, first truck in a long time. Had my girlfriend follow me today and its right, but the OD light wasn't blinking so.... IDK
Old Sep 22, 2009 | 08:15 PM
danr1's Avatar
danr1
Cruse control, horn and air bag do go through clock spring, OD light/switch and turn signals do not.
I second the, VSS sensor may be getting interfered with, could be metal shavings causing the intermittent problem. If the speed is not held about dead steady the cruse control will not activate. Problem is there may not be many stuck on it when inspecting it.
Could have other issues as well, a failing sensor, one or more of a small hand full but that is where I would look a minute, at that VSS sensor to start with.
Old Sep 22, 2009 | 11:25 PM
94XLT5.0's Avatar
94XLT5.0
I am guessing that the VSS is on the axle.
