Hi... 88K on my 2000 Mazda B2500 and the engine check light came on yesterday. It seems to start and run like it always did (good). I'm thinking of going over to Autozone for the codes but I would like to buy a code reader for the future. There are a number of them out there and I need a recommendation from the experienced for a good but reasonably priced reader. 2.5 4 cycl..
IHMO. Simple readers read DTC only and you will find description in internet (P0301I and that's all). advanced scanner decode and you'll get "P0301 - cyl #1 missfire".
Suffisticated scanners read engine data, actual values, they can do some engine tests, like compression test.
next level - vehicle - computer interface, that lets you use computer programm to diagnose electronic systems.
Better step - made by actia ore bosh universal scanners, KTM550 for example - does a lot.
But the best for vehicle diagnostics - used by dealers genue Ford scanner - FORD VCM TOOL. You can reprogramm engine ore tranny unit, retrofit new PCM, programm immo keys....
So what scanner to use? I suggest simple one, made in China, will be the best for you
I got my "scanner itch",when Pep Boys had the Actron CP9135 on sale for $29.99 after rebate or coupon?,can't remember.It was 2008.AFTER I got the CP9135 ,Actron says,It hasa the "New" one out CP9145! I couldn't find tghe codes for my 02 Ranger V6 3.0L Off road 4X4 XLT Supercab! "They"(Actron)said "basically the CP9135 was tghe same as CP9145!My Bro,longtime Mechanic AND Bro-In-Law(LONGtime Ford Dealer Tech,Now College Auto Tech Teacher,said Actron or Innova! They were the most common AND the ONLY ones I saw in our limited selection backcountry SoCal mountain town ,AutoPatrs Stores! I wasn't having Codes or CEL problem,just approaching the 100K miles wanted one ,especiallty under $50!Mine says "PASSED",but I've volunteered my services to acquaintences,who have CELs On ,or other OBD2 ,issues.I will be checking,these when They get time.Fihure aveage hookup for Scan at Service here is $80 or more! I got my "toy" ready,and figure like most tools,A Good Investment!
