DP Switch location?
Old Sep 21, 2009 | 10:14 AM
Rushmore X's Avatar
Rushmore X
DP Switch location?
Just wondering where you guys mounted your F5 switch. Had mine duct taped, but now have the metal holder, and want to mount it permanently. Think right side of column had the most room. thanks
Old Sep 22, 2009 | 11:13 AM
Rushmore X's Avatar
Rushmore X
Should have looked first
After posting did a search on the switch and saw what others had done with theirs. Ended up mounting right of the stearing column.
Old Sep 22, 2009 | 01:32 PM
aklim's Avatar
aklim
I mounted it in the empty space next to the power outlet.
Old Sep 22, 2009 | 07:17 PM
89LX306's Avatar
89LX306
Here is where mine ended up. I made this out of one of the original rectangle switches before DP made their gauge pod switch.
Started out like this.
Old Sep 22, 2009 | 11:37 PM
CanadianSmokie's Avatar
CanadianSmokie
I mounted mine where that vent thing is to the right of the ignition... just under where you mounted yours. Used a utility knife to cut two of the slats the right width and pushed the connector through. Didn't even have to use anything to hold it in place.
Old Sep 23, 2009 | 06:43 AM
Rushmore X's Avatar
Rushmore X
Same here, cut mine out with a dremel, and it's held in by friction.
