cleveland headers ??
Old Sep 21, 2009 | 08:54 AM
werneil's Avatar
werneil
can i use 4/1 headers from a 400 onto a 351, both from a 1980 f100, i don't mind a bit of work. any reply's appreciated
Old Sep 21, 2009 | 09:37 AM
bighead400's Avatar
bighead400
you can swap cleveland heads to a 351m or 400 so i'd just check bolt pattern & make sure the ports are the same.
Old Sep 21, 2009 | 09:46 AM
bighead400's Avatar
bighead400
let me be more clear on that, the block is the same, the heads are the same except compression ratio, same year truck, should not be a clearance problem for headers
Old Sep 21, 2009 | 12:48 PM
grclark351's Avatar
grclark351
as far as headers are concerned they're the same engine, but 2x4 headers in a 4x4 truck may be an issue
